If you check on the list to be able to connect on the internet Belkin does not appear
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
SOURCE: Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
SOURCE: wireless ready laptop not getting connected to internet through belkin router
You may want to check if the wireless switch is "ON"
on the laptop most wireless ready laptops has either a
button or toggle switch to enable the wireless radio..
if it's already enabled and you still cant connect to
the wireless network,try changing the wireless channel
from the router.
SOURCE: Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
SOURCE: i have belkin router connected
Reset the router: Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds. After you reset the router, restart your computer If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays! Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
