Question about Nordic Track NordicTrack C2150 Treadmill
C2150 beeps When I power on the treadmill it just beeps. When I press the stop button it stops but as soon as I let go it beeps
4 Suggested Answers
SOURCE:
  • 103 Answers
SOURCE: NordicTrack Z7xi treadmill console buttons not working
Hello there. It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed. (i.e. the 4 beeps). This is usually caused by the i-fit buttons (silver buttons on the front). If the machine is only 4 months old you should still be under warranty (1 year) I believe. This problem in most instances requires the console be replaced. You can contact nordictrack through iconservice.com or by using the number on the fron of your users manual.
Good Luck! Tim
Posted on Dec 16, 2009
roadtech7
  • 297 Answers
SOURCE: belt stops when you stand on it
Hi, yopu have a loose belt or a bad front roller, remove the hood(front cover), and start and run the treadmill. Get on it and watch to the left where the belt is, you are watching to se if the front roller is stoping when you walk on it. Most likley. you have a stripped plastic pully on the front roller. The belt and the pully turn fine, but where it is pressed on the steel drum (roller), it just spins. You need to replace the front roller.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Dec 01, 2011
ercupa190
  • 12223 Answers
SOURCE: Treadmill stopped working. Push any button on the console and it beeps. Unplugged, Reset, Checked Reed switch - seems to be in the right position. Unplugged again and it started then stopped a few
1)lube the DECK BELT, you have a lack of maintenance schedule. mAYbe you have a deck belt worn. This produce enough friction between deck vs deck belt and shut down the machine for to protect the electronic system.
2) Lube the rollers bearing in according with the maintenance schedule.
3) Test the voltage input motor, if there are the motor need repair.
4) Test the output voltage board,for input voltage motor, if there are NOT the board is faulty.
5) Try to run the software calibration for diagnose, troubleshooting,etc
6) SEe my personal tips for help.
sincerely. God bless you
Posted on May 08, 2012
My treadmill wont re-boot
follow this steps and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 11, 2013 | Epic A30T Treadmill
When turn it on just beeping noise
reset the treadmill. follow this steps and fix it. God bless you
1.
    • 1
    • 3
    • 4
    • 2
Oct 23, 2013 | Reebok Exercise & Fitness
Horizon t207
1.
    • 1
    • 3
    • 4
    • 2
Oct 08, 2013 | Horizon Exercise & Fitness
Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
1.
    • 1
    • 3
    • 4
    • 2
Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
The treadmill goes to full speed as soon as you power up the treadmill
Run the software calibration for diagnose, troubleshooting, and fix it.
God bless you
Jul 23, 2012 | Proform Exercise & Fitness
Lifetrack OMA-117 treadmill constant beeping not moving
1) adjust the REED swithc , see the diagram clean , and tight the wires connector very well.
2)Try to RUN the software calibration for diagnose, and troubleshooting.
God bless you
Jun 29, 2012 | Exercise & Fitness
Where is the reset button on Roger Black Gold Treadmill
resetting the treadmill especially on most merit treadmill is as easy as pressing and holding the "STOP" button until you hear a beeping sound and the display shows all zeros.
Apr 08, 2011 | Exercise & Fitness
The machine just goes into auto calibrating on the screen and beeps constantly. does not stop auto calibrating Just seems unable to cope with any programs to do with hill climbs
power off, put in the key, press and hold down the 'stop' button and 'incline up' buttons, power on holding down the buttons for a few seconds - message clears
Feb 17, 2011 | Tunturi T60 Folding Treadmill
My reebok treadmill makes only three beeps when you hit the sensor buttons
Plug in power cord, remove key, hold down speed+ and stop buttons, replace key, release buttons, press stop once, press and hold speed + until max. treadmill will run to top speed (s9.80 should read out 11.8 to 12.5.) It took a couple of times to get this to work for mine, but now it is OK. If unit does not run after several attempts then the console is probably bad and will need to be replaced ($410). Get another treadmill ! If it does run the console may still beep - problem is with IFIT card. You can get rid of the beeps by opening the console and unplugging the IFIT cable from the computer card if you want.
Feb 06, 2011 | Sport & Outdoor - Others
Nordic Track NordicTrack C2150 Treadmill Logo
65 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
