Question about Xact Communication XS034 Boombox
My xact boombox just stops - Xact Communication XS034 Boombox
    Problem Solver:
  • 13 Answers
Thanks to all of you for your detailed comments I found an easy way to repair the boom box. Many of you said that if you pushed down on the radio hard it would play so I tried it and I too had the same problem, but since it is impossible to stand all day holding the radio and get anything else done I figured if you can't lower the radio raise the plug! Here is what I did, first unplug the radio so you don't short anything out, then at the front of the plastic plate the radio plugs into gently pry it up with a lock blade knife (as a rule kitchen knives are too flexible) then get a small self tapping screw (the smaller the better) and screw it into the gap made by the knifeyour radio will now play without holding it
Posted on May 11, 2014
SOURCE:
Xact XTR2 will not turn on
Its likely that the unit itself is bad. Do you have another dock or boombox to plug it in and trouble shoot with? If it doesn't power up in multiple sources it could be dead. Either way, TSS Radio can help:
tss-radio.com
Jun 17, 2012 | Sirius Satellite Radio XACT XTR2 Satellite...
Xact stream jockey 11 sirius boombox xs034
Thanks to all of you for your detailed comments I found an easy way to repair the boom box. Many of you said that if you pushed down on the radio hard it would play so I tried it and I too had the same problem, but since it is impossible to stand all day holding the radio and get anything else done I figured if you can't lower the radio raise the plug! Here is what I did, first unplug the radio so you don't short anything out, then at the front of the plastic plate the radio plugs into gently pry it up with a lock blade knife (as a rule kitchen knives are too flexible) then get a small self tapping screw (the smaller the better) and screw it into the gap made by the knife your radio will now play without holding it
Aug 23, 2008 | Xact Communication XS034 Boombox
Need User Manual for Xact XG2206 Cordless Phone
the manual for xact xg2201 cordless manual works for the xg2206 also. . .and I found this manual today at getxact.com. Theo
Sep 06, 2007 | Xact Communication XG2206 Cordless Phone
Xact xg2400
I just bought the phone a couple of hours ago and i can't see any manuals in the box. I can't find one on the internet either.
PLS give a manual use for
Xact xg2400Thank you
Sep 04, 2007 | Xact Communication Xact XG2400 2.4 Ghz...
Powers on and off with batteries
i would say you have bad luck with boomboxes try getting an mp3 player. j/k
May 01, 2007 | Xact Communication Xact XS027 Portable...
Sirius problem
I have the same problem, when I contact Xact (through e-mail) they said that the unit would have to be replaced. They didn't say that THEY would replace it, but said it had to be replaced.
Mar 28, 2007 | Xact Communication XTR1 SIRIUS Radio...
Boombox does not maintain connection to radio
Here is the fix,Thanks to all of you for your detailed comments I found an easy way to repair the boom box. Many of you said that if you pushed down on the radio hard it would play so I tried it and I too had the same problem, but since it is impossible to stand all day holding the radio and get anything else done I figured if you can't lower the radio raise the plug! Here is what I did, first unplug the radio so you don't short anything out, then at the front of the plastic plate the radio plugs into gently pry it up with a lock blade knife (as a rule kitchen knives are too flexible) then get a small self tapping screw (the smaller the better) and screw it into the gap made by the knife the radio will now play without any problem!
Dec 18, 2005 | Xact Communication XS034 Boombox
Xact Communication XS034 Boombox Logo
71 people viewed this question
Top Xact Communication Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Xact Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
