Question about LG LMV1813ST Microwave Oven
Lmv1813sw noise from turntable - LG LMV1813ST Microwave Oven
Jvm1640bb 006
Yes it can be replaced. But first make sure the noise isn't coming from the guide roller assembly or coupler which is the plastic part in the bottom of the microwave that turns the turntable. .
Jul 19, 2014 | GE SpaceMaker Microwave Ovens
My microwave makes a grinding noise when running and the turntable doesn't work.
Possible there is friction within the drive , the shaft or the motor. You can remove and RESET the drive. Remove the motor , MANUALLY check the motion of the mechanism which will confirm the case. You c an reset using a bit of lubrication.
Jan 10, 2013 | Microwave Ovens
I purchased a panasonic nnsd797s inverter microwave in Febr 2010. The turntable appears to have been the source of noises for the past few months. It quited down for a while, but is not louder than ever...
The turntable motors cannot be lubricated, only replaced. The popping noises you mention, is that from the motor or from the microwave arcing??? Unplug the turntable motor and put a cup of water into the unit and run it for a little bit and listen, if it is stil popping you may have other issues.
Oct 06, 2017 | Panasonic NN-SD797S Microwave Oven
Turntable makes grinding noise and barely turns
Unplug unit and take bottom off of it with the screws that go around the outer edge. The turnatanble motor has 2 screws and is removabe from the bottom underneath.
Sep 24, 2017 | GE JES1851 Microwave Oven
Turntable makes a popping noise
The problem with turntable motor or coupler which sits on turntable motor shaft.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 30, 2008 | Whirlpool MH7135XE Microwave Oven
Turntables doesn't work and makes horrible noise
Replace turntable motor. Not really that hard to replace or expensive. Remove all screws holding bottom panel (usually three across each side and one to three in front) to gain access to the turntable motor. The panel will hinge in the back.
Jun 01, 2008 | Frigidaire PLMV168 Microwave Oven
GE Spacemaker JVM1631BB005 making noise
Many thanks to e3enigma above! I removed the synch motor under the turntable; all other microwave functions work fine and the grinding noise is gone, hooray! A trip to the appliance parts store tomorrow for a replacement synchronous motor and all should be well. Thanks again!
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Noisy when running - not the usual humming noise
check turntable motor or bush, this very easy problem, you can use oven no problem..
Nov 11, 2007 | Whirlpool GH8155XJ Microwave Oven
The turntable makes grinding niose when engaged
That model number doesn't ring a bell. Is that right? Is it foreign?
Chances are the coupler and/or turntable support will be damaged or warped.
Also on some brands, the "packing" (often a rubber grommet) must be replaced.
Oct 17, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
LG LMV1813ST Microwave Oven Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
