Televison & Video Logo
Posted on Mar 02, 2009
I need curtis tv remote codes for direct tv receiver
  • 6 more comments
  • Anonymous Mar 09, 2009
    I have a Curtis LCD1923A TV and can not find the remote codes for Direct TV.
  • Theresa M Mar 30, 2009
    I need the same thing - the DTV code for a Curtis tv NOT a Curtis Mathes as provided by DTV.
    I need the same thing - code for DTV remote for a Curtis TV not Curtis Mathes as provided by DTV
  • nesc25 Apr 02, 2009
  • nuctv Apr 04, 2009
    I have a Curtis LCD3215A and need the remote code for Charter Cable.
  • Anonymous Apr 22, 2009
    Does anyone know the code to program directv remote with curtiis flat screen?
  • Barbara Brengan
    Barbara Brengan Jan 16, 2014
    I need a code for Time Warner Cable, so I can use 1 remote.
  • Doug Moody
    Doug Moody Apr 01, 2014
    Try the Sony Codes I used 10000
Alf Berg
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 07, 2011
Alf Berg
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8617
Points
9
Just spoke to Curtis tech support. Most controllers not compatable with Curtis tvs, but there are three codes that will work with some remotes. They are 2622, 2295, 1218.
Hope this helps someone.
  • beyert1 Jul 20, 2011
    I have found the solution. I have a Sony TV and the Direct TV remote ended up in my bedroom with my Curtis television. I did not realize for 2 days I had the wrong remote. I finally programmed another remote with a Sony code and it worked like a charm. I did it even on a Universal RCA remote and it worked. So, the Sony codes work on the Curtis Television.
  • Doug Moody
    The Sony Code 10000 worked great for my 37" curtis
2 Related Answers
Anonymous
  • Posted on May 15, 2008
SOURCE: One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
reprograming ilo tv
Anonymous
  • Posted on Aug 13, 2009
SOURCE: philips universal remote #cl035a need rca tv, dir tv sat codes
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
I hope that this link helps you!!!.. Your Welcome.. I had the same issue.. tried this and hey! it worked.
How do I get a code for the Philips Universal Remote to work on a Curtis LED 1930A TV
Remote working, 5voltage okay. Sensor replacement.but receiver not working
Direct tv remote rc65/lcd2425a Curtis tv code
I was about to give up and the last thing I tred worked as a full remote.
Use any cell phone I have android. Download free Peel Smart Remote. When setting up remote choose Sony. Works like a charm.
11helpful
Need the code list for quantum view model QTC32A7F to set remotes
I found a perfect fix for the 32 inch Quantum View TVs with a DirecTV remote.
Press Menu (on your directv remote) , go to settings/help>Settings>RemoteControl>Program Remote>TV.
When prompted to choose a brand, select CURTIS MATHIS. The codes from Curtis Mathis should match the codes for your Quantum View TV.
Note: Make sure the remote can 'see' the receiver during this process.
I have a universal remote control that I want to use with my Curtis Mathis TV. What code do I need to use to make the remote compatible with the TV?
Hello
Thee digit universal remote code for Curtis Mathis are:-
000/ 001/ 004/ 009/ 015/ 031/ 049/ 105/ 109
Four digit universal remote codes for Curtis Mathis are:-
0031 0105 0130
0004 0009 0000 0049
0109 0358 0001 0015
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Need Direct TV remote code for Curtis LCD2603A TV?
some of these will not work with certain tv's. your direct tv remote should be able to code in your tv with this direct tv or try their website for more answers
I have a new curtis lcd 3717A tv and need the code for the direct tv remote. Can anyone help?
It will be one of these codes. You will need to try them.
00,06,11,15,21,50
Need code to program Zenith remote control
Try these codes for your remote and TV. The are the Zenith codes for a Curtis Mathes TV.
CURTIS MATHES.....002 103
............................. 112 502 506
..................... 512 601 701 704
These should work.
Regards,
Mike
I am thinking of purchasing a universal remote to handle my Direct TV, Toshiba TV and Curtis DVD. Is there a code for a universal remote that can be used on the Direct TV? Gary Stroble
You can use the Directv remote to control all those devices.
Curtis DVD code; 21087
Toshiba TV code: 10156 11656 11256 11356 10650 10060 10154 10765 10178.
27helpful
4answers
Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Codes
I have found some Curtis codes you can try. 00, 06, 11, 15, 21, 50.
If those do not work, does the cable remote have a "learn" function?
This is where you point the cable remote at the TV remote face-to-face & press all of the pertinent buttons on TV remote in order for the cable remote to "learn" what codes th e TV remote is generating for the various control functions. If the cable remote does have this function the users guide will give you step-by-step instructions. Barring that contact your cable provider.
Keep in mind that there are so many TV models being produced by numerous manufacturers these days that it maybe possible that your model's remote codes are not compatible with anything than another Curtis product. You may have to contact Curtis directly.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
