Question about New Bright Remote Control Toyota FJ Cruiser
Forward does not work - 19.2 V New Bright Buggy
Reverse works fine and forward stops the wheels suddenly but without transfering to forward direction.Exactly the same problem. I've thought about reversing the motor wires at the receiver so that reverse becomes foreward. Anybody tried that?
  • 19,396 Answers
That should work, but then you need a way to use also reverse.
Posted on Mar 02, 2009
    Scholar:
  • 165 Answers
Its 1 line short in the unit that has to be checkede and made clear.this will solve check the voltages in both lines.
  • y_rogach
    y_rogach Dec 29, 2012
    How to check and clear line?
SOURCE:
Fisher price power wheels dune buggy will not work when put in the forward gear but it will work in the reverse gear
check to see if both wheels are spinning in reverse, if not one of the motors is bad or disconnected and this will affect the forward gears
Feb 04, 2013 | Toys
New Bright, F-150, Red Thunder 4X4: Truck goes into "static" mode when forward or reverse is pushed on remote. In other words, truck starts up when turned on, steering, horn and lock work fine,...
Get new battery, I have 4 batteries, all will turn it on, get horn lights, sound. 2 do the exact same thing yours is doing, 1 runs about 5 min then starts into your problem, 1 is good and will run for about 20 mins.
Aug 27, 2011 | New Bright Ford F150 Rc
Transmission suddenly stopped shifting. It works in 1-2nd &R. Was working fine then would not go forward and would stall the engine. It was like the wheels locked up going forward only, reverse was...
The transmission solenoids are not working properly. Probably requires a transmission rebuild.
I don't think it's in the ground strap or wiring.
It's an internal problem with the transmission.
Aug 26, 2010 | 2002 Chrysler Sebring
New Bright Model #183 - how do I make the train go? The light works when the engine switch is in forward and reverse, but the train doesn't move (wheels do not turn). The music plays from the coal are -...
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Nov 27, 2009 | New Bright 181 Toy Christmas Train
It is a problem with the circuit board. To my knowledge New Bright does not have anywhere that you can order the board.
Feb 23, 2009 | New Bright Remote Control Toyota FJ...
Little gem mobility scooter brake not working properly
The throttle part has slip round, a way to test this is to put hte buggy in reverse slightly and it shoud stop, meaning that how much the throttle has slipped round. Take the top cover off and there should be a allen screen on the throttle stem, undo and readjust.
Oct 02, 2008 | Drive Medical Mini Phantom Three Wheel...
New Bright Remote Control Toyota FJ Cruiser Logo
141 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
