Hi, I would like to move my Sanyo freezer ultra Low temp VIP series for few meters but I've to unplug it from the electricity outlet, by the way, there are wheels that make it easy to move on the floor.
I've to mention there are some frozen samples in it and I'm worried if I unplug it and relocate it then didn't work! any help. ThanksI've to mention there are some frozen samples in it and I'm worried if I unplug it and relocate it then didn't work! any help. Thanks
No. Sounds like the intern temp sensor is bad, missing, or not connected. 92 is probably the max reading it can display. The unit will probably operate continuously, be much to cold, and cost a ton to operate. I assume you bought this from Sears. Call them to replace the freezer. Should be no problem.
Unplug it for a couple of hours so that the door seal would thaw if its blocked with ice...You can use a blower to thaw it soon after unplugging the freezer....
the freezer is froze up and will need to be derosted, use a fan to speed this process along can take upto two hours to defrost, keep whiping the inside dry as you defrost = unplugged fridge . what happens is the cooling coils get covered in ice, and will not it yo cool properly .. so you don't forget make a note on the door to make sure you SHUT ME TIGHT .. hope that was of help, click on the yes if it was .. jay the pool pump guy
DO NOT TRY TO MODIFY TIMING CYCLE.you would need to completely modify printed circuit board and inbuilt computer......some freezers cycle around 6 to 8 hours.the temperature can only be checked say every 12 hours to get an average reading
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
yes it is not work
