It has been working fine for couple of years now, only recently it started to have this issue when you pres print for one copy of the document the printer decides to print 2-3 copies of the same document and most of the time pulls out blank sheet of paper between the pages of the document. I have tried to default it, updated the firmware, re install the driver and nothing has fixed the issue
SOURCE: samsung CLP-300 dark prints and smears
For starters remember this is not meant to be a PHOTO Printer, I am guessing the Spearing is because Glossy paper does not hold the toner like Regular paper or at least until it is fused. I am a technitiian and i also own this printer.
SOURCE: Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
SOURCE: Samsung CLP-315W Color Laser Printer will print only half page
http://www.fixya.com/support/t3934542-exit_sensor_problem_samsung_clp_315
SOURCE: My Samsung scx-4521 will not copy or scan
hello this is a problem with your scanner unit. check it out. replace scanner cable.
