SOURCE: Message on Brother MFC
Open door
press Clear/Back key
press *00
press OK
Do not
choose anything for drum replacement. when drum replacement menu comes
up, just press the * and then 00, then just press OK.
that should clear the error message, the printer has a toner life counter that needs to be reset.
SOURCE: Brother MFC-9440CN Laser Printer is
If you want to reset your Brother MFC 9440N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 9440N should be reset and the Toner End of Life message should disappear. Warning, this may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
SOURCE: I have MFC-7340 Brother Printer but I have
Open the front cover.
Press the clear/back button.
It'll ask if you want to replace the drum, but ignore that and just press *11 quickly. It should say "Accepted" on the LCD. Close the cover and it should work.
SOURCE: My brother mfc-7220 printer show"toner
You do not necessarily need to replace the toner right away. The toner has 2 visible clear tabs when you are looking at either side of the toner cartridge. This is for a reader built into the unit to recognize that the toner is low. However, if you cover those clear plastic pieces with black electrical tape, you will be able to achieve an additional couple hundred prints and when the toner no longer prints on the page, you are definitely out of toner.
