Your description is very incomplete. Does it not start turning until the lever is at position 8 or does it run at high speed from the moment it starts at position 1?
If it's not starting until position 8 then the problem is probably mechanical and will require some parts to be replaced or adjusted.
If it starts on high speed at position 1 then it's likely you need to replace the phase board under the back cover at the top.
Whatever you decide to do check the carbon brushes first as worn out brushes can sometimes create funny speed problems.
Contact support and request a new activation code, you can not use the older one, because is already used, ask to resend a new activation code. Hope this help.
contact your local deeler on the phone supply him your vin no. (found on your id plate rivioted to body under bonnet) and some regestration details he may be able to help .
Hi, This is unfortunately a problem we all experience at some or other stage. It would be easy for me to send you a working registration code to get your game installed. This, however, could have legal implications due to copyright laws set up by the game producer, namely Electronic Arts in this case. Your best bet will be to contact EA via their website and explain your problem and also submit all evidence as to prove ownership of the game. Let me know what the outcome is so that I may assist you further if necessary. Best wishes, Graemevm
The reg key is located on the disk cover inside the box....if you don't see it you'll need to goto the 120% site and work it out with customer service , not on fix ya :-P
