Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Try this clip I have just found, hope it helps. TRY 0335 OR 0060 PRESS TV ON YOUR SKY TV REMOTE , PRESS RED & SELECT TOGETHER UNTIL RED LIGHT FLASHES TWICE , PRESS TV ENTER 0335 OR 0060 PRESS TV AGAIN THEN THE OFF BUTTON IF THIS TURNS OFF YOUR TV SELECT IF NOT PRESS TV THEN THE OFF BUTTON AGAIN REPEAT THE LAST BIT TILL THE TV TURNS OFF THEN PRESS SELECT ; DONT RUSH THIS BUT FOLLOW THIS TO THE WORD HOPE THIS WORKS FOR YOU . I FOUND THIS ANSWER ON THE WEB IT'S BY AN EX SKY ENGINEER . GLAD TO HELP...
A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Parts are not available from the manufacturer because they are assembled in China and the components are ordered for a run of complete products, not spare parts.
Try ebay for a non working set that has a base.
Try monoprice.com for a stand that fits your set.
It is hard to find manual for a phone using the serial number of the base and hand units. Please check if the Logik phone is one of these models
L15DTAM10
L25DTAM10
L35DTAM10
The manual for these can be loaded from
if i'm not mistaken all you do to register the phone is put the handset into the base unit ... i believe the light flashes for a sec then it's registered... repeat that with all the handsets you have. it will not be registered if you have put the handset into the spare charging stand if that is included with your phone.
