hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods
DX 2527 -
VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range,
VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF
Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC,
VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC
2....10.240.
DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB
Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR
6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR
9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver
Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation
Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power,
VR601..13.8 Volt Power Supply.
DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB
Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier
Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC,
VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low
Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240.
DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR
3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM
Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final
Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power,
VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias,
VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low
Power.
DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR
2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch
Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF
Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC,
VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power,
VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for
DX 77HML only.
DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM
S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF
Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power,
VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power
(DX 33HML only) Unmarked VR in C139..Med Power AM modulation
(DX 33HML only)
DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR
3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier
Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias,
VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM
Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low
Power, VC1....10.240.
DX 2517 and DX 2527- Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power
2SB817 100 Watt 12A. Derating of this component will cool operation,
provide better voltage stability,decrease wobble, allow voltage
increase to 14.5 volts comfortably. (replace 10 volt caps in this
section of the radio to a minimum of 16 volts before increasing supply
voltage to this level)and provide faster swing rise time, Replace Q37
2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and
volume of the modulation and it will also run a lot cooler.
took the back off of it today and guess what....the wire soldered to the coax connector from the board was broke off... soldered it back on and tightened up the connector....and she works! man they must put some tough finals in those radio's..
