This is wat i got... i ran each dvc(mtx 8500 12") series to itself then parallel with 1 svc((kicker comp 15") 4 speakers total. my amp is a mtx jackhammer good down to 2 ohms at 600w rms. the setup hits but not as good as it used to... any ideas on wiring options? i have 2 seperate slot port boxes
SOURCE: subs will go off the wall with bass, but not in tune with music.
hi, first disconnect the rca input, then switch on headunit and if the amp produces a constant bass thump it then means it has an internal fault. if the amp idles quietly then replace the rca cable, or try connecting the headunit lineout feed directly to the bass amp, in this way you cud find out if your fault is coming from the headunit or the equaliser. cheers
SOURCE: I own a mtx 1501d.Also own a 18
THE AMPLIFIER NEEDS A 1 OHM LOAD AND YOU HAVE THE RIGHT SPEAKER TO PROVIDE THIS LOAD. THE AMPLIFIERS TERMINAL STRIP PROVIDES YOU WITH 2 POSITIVES AND 2 NEGATIVES, BUT THEY ARE ONLY FOR CONVENIENCE WHEN WIRING 2 DRIVERS. ACTUALLY THE 2 POSITIVES ARE THE SAME CONNECTION INTERNALLY ON THE BOARD, AS WELL AS THE 2 NEGATIVES. THAT BEING SAID, THE SIMPLEST WAY TO CONNECT YOUR SPEAKER IS TO PARALLEL THE VOICECOILS IN THE BOX BY CONNECTING THE 2 POS. TOGETHER AND THE 2 NEG. TOGETHER THEN RUN THAT POS. AND NEG. OUT OF THE BOX AND SIMPLY CHOOSE EITHER OF THE 2 POS AND NEG. OF YOUR CHOICE AT THE AMP. IF YOU EVER HAVE TO ADD A SUB, THEN YOU WILL HAVE 2 MORE TERMINAL LEFT OVER ON THE AMP. TO CONNECT IT TO AT THAT TIME. BY ALL MEANS, IF YOU WOULD LIKE TO RUN EACH COIL SEPARATELY OUT OF THE BOX AND CONNECT THEM TO ALL 4 TERMINALS, THEN THIS IS FINE TOO, AS EITHER WAY, THERE WILL BE NO DIFFERENCE WHATSOEVER. LET ME KNOW IF I CAN BE OF FURTHER ASSISTANCE....V
SOURCE: can you bridge 2 4
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
