I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
The last two numbers in the model number indicates the Btu ratings. The mxz4a36 indicates that this unit is capable of putting out 36,000 Btus and only 30,000 Btus on the other. I would be concerned that the second unit is large enough to satisfy your cooling load. Forget the power, make sure the unit is sized properly.
go to their website and enter model & model #- find a click for specs.- should list max. ram and cpu capabilities. unless cpu is removable, as a desktop- which i doubt- i have a satellite m35x 1.3. you may need to replace the mobo (mother board), which can be really hairy!! see if you can upgrade your ram- it will make a rather significant difference in performance- can also install larger capacity hd. try 'flashing'- upgrading your bios- if your system isn't 'brand new'! you may have that option on the toshiba website. good luck!
The radio will have to be removed from the car dashboard .Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING. Also quote the MAKE of CAR it is fitted into. Please note: Not all stereo codes can be calculated from the Serial Number
