Tascam DP-008 8-Track Pocketstudio Logo
Posted on Mar 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SD Card Full
Recorded a 5 hour gig need to export track the recorder tells me 8 GB SD card is full, will it erase any data by switching to a bigger GB card?
Anonymous
Level 3:
  • Master 32,281 Answers
  • Posted on Mar 26, 2013
Anonymous
Master
Level 3:
Answers
32281
Questions
Helped
7913026
Points
102259
When you install a larger SD card it will be a fresh empty memory card. Your existing 8Gb SD card will still have the the 5 hour gig data on it.
You can insert the 8Gb SD memory card into an USB memory card reader and plug this into the USB port on your computer. The computer will see this SD memory card and adapter as an external storage device. You can then open the audio folder on theis SD memory card and copy this file to your computer.
1 Related Answer
A
Anonymous
  • Posted on Dec 06, 2007
SOURCE: tascam pocketstudio 5
buy a roland vs2480
1helpful
When I try to burn recorded track, shows a message CD full when I check remaiing spcace, it shows full available
i think the maximum capacity of a CD is between 750MB to 850MB . since the error message is CD full better check the amount / volume of data to be transferred to your CD .
Aug 27, 2014 • Cameras
DMC-zs10 records on internal memory - not on SD card
Hello bro..
Do you check your SD card? It is work ?
My solution:
1. Off Lumix camera.Until LCD was off. Press center of card to remove it.
2. Use card reader to connect your SD card to pc/netbook/laptop..
3. Check full capacity for SD card, it is empty(zero) or have it their mount.
4. If empty (full,used,free is zero) ,try reinsert card again and don' t touch the terminal.
5. If still empty, that mean, your SD card was corrupted.
6. If not empty, backup all data in SD card.
7. Format the SD card using FAT32.
8. Checking Disk.
9.Insert back to camera, and format SD card using camera menu.
10. Take picture. and see if save on SD card or not. comment back here. if succes or not.
11. Don't use any battery except original from panasonic. It will affected to product.
12. Don't remove battery or card before lcd was off light.
Jul 24, 2011 • Cameras
1helpful
What kind of memory SD card would work for Panasonic DVD Recorder DMR-ES46V? I was hoping to put in a 8 gig memory card but those are all SDHC. Will those cards work in this unit?
This info is straight from the panasonic website. The owners manual and more info for the unit can be found here.
Hope his helps!
Suitable SD Memory Cards
8 MB, 16 MB, 32 MB, 64 MB, 128 MB,
256 MB, 512 MB, 1 GB, 2 GB (Maximum)
Panasonic PVGS-50D SD memory card
Check your manual for the max supported SD card size. Most likely it will either support a minimum of 2-4 gb :)
So yes you can get larger cards for your PV GS 50D
Regards,
Shadowmaru
1helpful
3answers
Memory is full
You can only use a 2GB SD card. It is in the manual. I'm not sure on dvd.
16helpful
2answers
"Card Full" error when the card is in fact empty...
I had the same issue, and ended up solving it after trying many different things. So first you put the card in your reader, right click, and hit "format...". It should ask you if it's ok to erase everything. Say yes.
Then put the card in the recorder, and it should say "Unformatted". Hit Utility and TR4 to Initialize. That should do the trick. Hope that helps!
11helpful
5answers
Zoom H4 Recorder Says, "Card Full!" But it is NOT!
I encounter this error with my 16 gb SD card and Zoom H4n.
I try to format the card inside and outside fo the Zoom, use 8 gb and 32 gb instead of 16gb card and, but get the same error.
But I find a solution.
1. I format my SD card inside Zoom with builtin utility. (Menu - SD Card - Format)
2. I reinstall Zoom firmware
(instruction and download here: http://www.zoom.co.jp/products/h4n/software/ )
3. I format SD card inside Zoom again.
I took a several test and didn't get a "Card Full" error.
1helpful
Memory
Ok, here's the deal...
The '9 hours' of recording time is a bench mark only... The unit only comes with 64 MB of internal memory, and when you are recording in the highest resolution, (Mpeg4) mode, then it eats up the available space really fast. Keep in mind, that in high resolution video mode, as opposed to standard, you will eat up at least 64 in about 7 minutes, not 5.
I dropped a 512 MB SD card in the camcorder, and on high resolution video, you might get away with 45 minutes to and hour. The camcorder records in 640 by 480 resolution, which isn't bad, but certainly isn't in DVD quality either...
So, pick youself up a 2 GB SD card, and you will certainly get up to at least 5 hours in standard mode. Rule of thumb, 400 MB per hour in standard mode. But, if you also go into the camera mode and take high resolution photos, that will also eat up your available storage ability...
Any other questions, just let me know...
2answers
Unformatted sd card in xacti camcorder
I have one sd card HAMA 12 GB and my computer and another computer canoty read my cd card iI have so much photo and video and my computer sad o bytes. Why ? I have photo and video i don't like delete . my cd hama card is 12 gb
Top Tascam Audio Players & Recorders Experts
John
John
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
