Konica Minolta Magicolor 4690MF Multifunction Laser Printer Logo
Posted on Mar 25, 2013
4695mf caution toner empty change k toner - Konica Minolta Magicolor 4690MF Multifunction Laser Printer
Minolta 4695 claiming the yellow toner is empty, but it's full??
using 3rd party toner or OEM. use OEM and replace the Image unit with OEM.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
4695 DUMPING TONER
replace toner and check the image unit with that color use oem not third party
Black strip down paper appears on first few pages
buy OEM not third party
Terrible copies down the sides !
759a6310-c94d-4cc9-8251-468d69129a1d.jpgIF IT LOOKS LIKE THIS, LONG STORY SHORT REPLACE BLACK IU
SEAMS TO BE TRIGGERED BY HIGH HUMIDITY
2helpful
2answers
Printer display message (toner empty replace toner) but print out is ok
Hi there
this is just telling you get ready to buy a new toner for your printer.
All the best Pineworks
Empty waste bucket on cannon 3050
If this is on a Canon NP3050 copier, the waste toner is stored in the drum unit. The developer unit needs to be released away from the drum unit before removing it (drum unit). There is a plastic lid to remove to empty waste toner. Use caution when emptying, it is easy to make a mess.
Magicolor 4695MF manual
go on google.com and write magicolor 4695MF manual then there will a pdf in search results click on it and you ve got it
How do we empty the waste basket?
The "waste basket" is to indicate that the waste toner area in the drum cartridge is full. If the copy quality is still ok you may be able to empty the waste by removing the drum cartridge from the machine and removing the opaque piece from the left side and dumping it out. BE CAREFUL this can be very very messy. toner is a very fine powder and will get all over the place if caution is not used.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
3helpful
Yellow toner empty
You will need to use the menu on the printer itself to change a setting Press "Menu Select" button to get the menu function Use the right arrow twice to select "Engine", then press the down arrow to the "Replace Toner" menu Press the right arrow for the "Toner Empty" menu Press the down arrow to get the Toner Empty settings Press the right arrow to change the Toner Empty setting to "Continue" Press the "Menu Select" button to confirm the setting. You should be able to print, you just won't have any yellow toner. When you get your toner cartridge, follow these instructions to reset the 'Toner Empty' setting to Stop so you will know when a toner is out.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
