SOURCE: can't enable manual white balance and other options on nikon d40?
white balance can only be manually configured on "PSM" modes only, the other modes set the white balance automatically .
SOURCE: Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
SOURCE: need to change language on Nikon D60
Within the menu items that can be viewed on the back of the camera, there is a language option that you can set. You may have to scroll through all of these to get the correct setting. Nikon tends to change the menu layout from camera to camera, so it may not be the same in your D60 as it is in a D300 or other model.
SOURCE: Scratched Low pass filter on the sensor ! Nikon d60
all filters are available on Ebay or from a good camera supplier
SOURCE: Have a Nikon D60 and after I take a photo, I get
You need to press the Disp/Display button to remove the settings on the display.
Testimonial: "Also had to use the multi selector to get rid of it. I now understand the process. Thanks"
