Hi, i have a Caeco Incanto cappuccino machine which now has 2 green flashing lights and one red flashing light when you turn the machine on. the green ones are the short and long back select buttons and the red one is the water level indicator. the water tank is full and I don't know what else to check for, can you make any suggestions? the water light flashing is supposed to indicate "load the circuit" which means what? regards Hartmut
I have the same problem. It seems that the group motor issues. I ve opened up and found the group motor is coming some sparks. I know very well Saeco Magic Cappucino , Saeco range is more or less the same, Saeco incanto, first time deal with it , somebody just brought it to me to check it. I might fix it if find parts for it.
Load circuit means a lot, flow meter, pomps, could be the electronc board, bewing unit blocked up with coffee, so basically there is no water in circuit water or is air in water circuit....You have to check everything,
