On the brand new Kitchen Aid convection microwave, with food warming, just quit for the second time. (it's a month old unit.) The error code that showed up on the digital screen was: "F6 E0 Communication Error".
No troubleshooting page in manual.Error codes continual replacing the time.
Hi. this code represents a key pad or control board malfunction. you will have to make sure the key pad or control panel connectors are connected tightly and securely. If the wires and connectors are secure, the actual control board may be faulty and you will need to replace it at this point.
This is a Electronic board and touch module communication error.
1. Disconnect power for 1 minute.
2. Reconnect power.
3. If failure remains, replace board connection cable between touch control module and electronic control.
4. If failure remains, replace the electronic control.
5. If failure remains, replace the touch control module.
Turning off oven for 60 seconds worked like a champ. Thanks a million or at least $100. JeffG
SOURCE: Problem with the KitchenAid 30
well i will give you a link to suggestions that have already been made by other experts on Fixya. click here A. Unplug oven or disconnect power. B. Open the back panels and make sure the P6 and P2 connectors are fully inserted on the appliance manager and on the lower oven user interface board. - If they are not plugged in, plug in connectors and go to step F. - If they are plugged in, go to step C. C. Visually inspect all wires between P6 on the appliance manager and P2 on the lower user interface. - Make sure wires are not cut or pinched. - If the wires appear to be intact, perform a continuity check between P6-1 of the appliance manager and P2-1 of the user interface board.
otherwise,
Please reply back with your model number so we can help you.
