Hi there. We have just had a new kitchen installed with induction hob. It's great but my husband must have had the ring too high when frying an egg and as a result- the bottom of the frying pan is scorched and there is a black ring mark on the hob. Is there anything that will remove this?
Thanks for this suggestion - haven't actually tried it yet but it's encouraging to know that there is hope for this problem. Many thanks.
Marilynn WhiteThanks for this suggestion - haven't actually tried it yet but it's encouraging to know that there is hope for this problem. Many thanks.
Marilynn White
AnonymousMar 12, 2014
when i try to turn it on is not working and give me L singwhen i try to turn it on is not working and give me L sing
AnonymousMar 26, 2014
is there a function on this induction hob that allows the control sounds to be silencedis there a function on this induction hob that allows the control sounds to be silenced
One ring makes a very loud buzzing for the first few minutes of cooking??One ring makes a very loud buzzing for the first few minutes of cooking??
AnonymousMar 31, 2014
Have no power in induction hob but I have noticed there is a connector from the circuit board that goes nowhere.Have no power in induction hob but I have noticed there is a connector from the circuit board that goes nowhere.
You can't post conmments that contain an email address.
An E6 error code on a Belling induction hob typically indicates an issue with the power supply or the circuit board that controls the back two rings. Here are a few steps you can take to troubleshoot the issue:
Reset the hob: Try turning off the power to the hob for a few minutes and then turning it back on. This can sometimes reset the circuit board and clear the error code.
Check the power supply: Make sure the hob is receiving a stable and adequate power supply. Check the circuit breaker or fuse for the hob to ensure it is not tripped or blown.
Check the wiring: Inspect the wiring and connections for the back two rings to ensure they are not loose or damaged. Tighten any loose connections or replace any damaged wiring.
Contact a professional: If the issue persists, it may be a problem with the circuit board or control module. In this case, it's best to contact a professional technician or the manufacturer for assistance with repairs or replacement parts.
I hope this helps you resolve the issue with your Belling induction
i presume that you have a induction cook top. if so not all pots and pans will work on them. i have never had one but i do know this could be your type of problem. do some research on what pans to use on a induction stove.
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
hi i have a eurokers ceramic hob and it has not worked in about a yr. it is touch screen and only 1 mth old when problem happend it was like it over heated and now when you turn it on it flashes on the dial i cnat make out it and the hob wont come on. pls help it is brand new and dont want to throw it out.HELP PLS
check that the hob is wired correctly underneath 1,2,3 should be linked together as live 4,5 as neutral and earth takes its place as earth,
if it is wired correctly then i m afraid the hob needs a new induction element it is all one complete unit on these hobs not seperate so your looking at £1000 + to fix it plus engineer call out charges
Marilynn White
