Question about Canon PIXMA MP460 All-In-One InkJet Printer
Canon mp460 wireless printing
I have a bluetooth dongle plugged into front usb port on my canon mp460, i can print direct from my phone but cant print from computer, i am running vista and blutooth on computer is via another dongle
  • gav9579 Mar 03, 2009
    thanks for helping, drivers are installed as printer works fine when connected via cable, printer info bar says printer offline when i try via bluetooth, any more help will be greatfully recieved.
    Sergeant:
  • 239 Answers
You need to in stall the drivers on your computer for the printer. and make sure you phone is not connected to the printer at the time you are trying to use it with your computer as this can cause problems to.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Posted on Mar 01, 2009
SOURCE:
Hooked hdmi dongle to projector. Used kindle fire hdx. Picture works fine but no sound from projector speakers. No sound from kindle speakers. Need to use kindle headphone jack for sound.
follow this steps and fix it. God bless you
Check the system requirements on the Bluetooth dongle. If your system does not fit all the requirements, the device is not going to work. The requirements for the Bluetooth dongle are printed in the user manual and packaging. You may compare this to what is running on the computer by clicking "Start," "Control Panel" and "System." This displays the hardware running on the computer.
    • 2
Disconnect the Bluetooth dongle, restart the computer, then plug it back into a USB port. If you power on the computer with the dongle already instead, the system may not detect the equipment. Restarting the computer and performing this action helps correct the problem.
    • 3
Remove the Bluetooth dongle from the USB port and plug it into a different connection. Some USB ports fail to detect certain computer hardware. Changing the connection port fixes this.
    • 4
Install the driver on the provided driver installation CD. Without the driver, the computer is unable to detect and use the dongle. Insert the driver installation CD into the disc drive of the computer, then follow the on-screen steps to install the driver onto the system.
Oct 29, 2013 | Brookstone HDMI Pocket Projector
I have purchased a bluetooth usb dongle and cannot see where to plug it into my aspire sa80 computor
Hello there.
I have found a picture of the back of your computer. Please see below. The picture is a little small im sorry.
A bluetooth dongle connects over the USB port in your computer, while you have some slots in the back you should have some in the front as well. They look like this:
Hope this helps.
May 28, 2008 | Computers & Internet
Tip
How to Fix a Bluetooth Dongle in a computer
<p>Bluetooth devices connected to a computer system via a wireless signal, so that the desktop of annoying cables and wires to strip. Even if your computer does not have a built-in Bluetooth receiver, you can create a Bluetooth dongle, the function adds the system to connect. If the dongle is not working to resolve the situation. <br /> <p><br /> <p>1. Check the system requirements for the Bluetooth dongle. If the system does not fit all the requirements, the device will not work. The requirements for the Bluetooth dongle can be printed in the manual and packaging. You can compare that with what is running on your computer by clicking "Start" "Control Panel" and "System". This gives the computer hardware. <br /> <p><br /> <p>2. Unplug the Bluetooth dongle, restart the computer, plug it into a USB port. If you leave power on the computer with the dongle already instead, the system can not detect the devices. Restart the computer and perform this action helps to correct the problem. <br /> <p><br /> <p>3. Remove the dongle from the USB port and plug it into another compound. Some USB ports do not meet certain computer hardware detection. Changing the connection port fixes this. <br /> <p><br /> <p>4. Install the driver on the included CD driver installation. Without the driver, the computer can not detect and use the dongle. Insert the installation CD driver on your computer and follow the steps on screen to install the driver on the system. <br />
on Jun 26, 2011 | Computers & Internet
Usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Apr 10, 2013 | Computers & Internet
I cannot get Acer keyboard KG-0570 to connect with the computer. Possibly it is not turning on, but with no lights in the keyboard I cant tell. (using stylus to write this) The keyboard came with the...
is this connected wireless or bluetooth
if its bluetooth you have a permissions issue.
if just wierless dongle the dongle may be faulty try another usb port
if it is a usb conection then the usb legacy in the bios needs to be changed.
re-start the comp pus F2 thats will take you into the bios find usb support enable it job done.
Mar 15, 2011 | Acer Televison & Video
I cannot activate my bluetooth in my pc. please tell me steps to install and activate my pc bluetooth
Is this a laptop with built in bluetooth reciever? because if it is not, you will have to buy a bluetooth usb dongle for your pc and install it in order for your phone or other bluetooth device to communicate with your pc. A desktop pc does not have a bluetooth reciever built into unless otherwise stated by the manufacturer. 99% of all desktop systems do not come with bluetooth recievers.
you can find reasonable bluetooth usb dongles here:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=bluetooth+dongle&x=0&y=0
Once you have one, it's usually as easy as just pluggin it into an open usb slot on the back or front.
USB is a rectangular shaped port on your computer, there are usually atleast 4 ports on the bakc and 2 on the front, the front ports can be hidden under a plastic panel, or at a 45 degree angle downwards toward the desk as is in some dell models.
Jun 17, 2010 | Microsoft Windows XP Professional for PC
Whant to print wireless with my Canon MP390 printer
Ho,
No this will not work as the printer has no way to install the dongle into it's operating system.
In order to make it wireless you will need either a wireless access point if the printer already has an ethernet port a wireless USB print server if not.
Look at model # PM111UW on www.startech.com for refernece.
Chris
May 28, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Not printing from my laptop
If you have inserted the USB cable into the slot on the front of the printer, it will not print from the computer. That slot is for direct printing from a digital camera. You need to insert the USB cable into the port on the back/side of the printer. The port is almost square in shape, and should receive the end of the USB cable that is square with two rounded corners. The other end of the USB cable, much more rectangular, goes into the USB slot on your computer.
Apr 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA MP610 bluetooth not working
I can print to my cannon mp610 using my bluetooth connection, but cannot scan using it. Any ideas?
Jan 17, 2009 | Canon MP610 Photo All-In-One Printer
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
1,518 people viewed this question
Clive
Clive
old marine
old marine
Ekse
