Question about Google Android 4.0 7 inch 1080P Video Capacitive Screen 16GB Tablet PC
I just purchased a google android 4.0 m710 and it doesn't work. I charged the battery for about 8 hours. the only thing that displays are the bottom left icons and the time on the bottom right. wh
How do I install google play store
If you're in Google Chrome, type "Play Store" in the URL line at the top.
Then you can choose play store download.
Hope this helps.
Mar 07, 2015 | Apple iPad 2 MC979LL/A 9.7" 16 GB Tablet -...
Nextbook8 on charger 8 hours. An only 60% charged this time?
Good evening
This happened to my iPad. When I discovered that there were many programs open, I closed them and it charged.
hope this works for you as it did for me. Some one told me that it was a good idea to plug the tablet to a computer and charge it that way.
kolbrun
Feb 08, 2015 | Nextbook Premium 8 Se Android
Battery will not charge
Your battery may be defective and cant hold a charge. Make sure the unit is receiving power and if so replace the battery.
Dec 15, 2014 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
Just purchased 9" tablet..does it have to be fully charged for it to come on?
No. But the battery may be dead. Plug in the charger and then try to turn it on.
Oct 15, 2014 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
Why wont my nookhd wont charge
If it\'s only two months old it may have a defective charging cable or adapter. If it\'s a new purchase and you can return it. To check to see if it might be the adapter and not the charging cable you have a few cheap ways to test this out.
General charging recommendations.
If you get power leave it on charge at least 3+ hours. This is the minimum time required if the battery is totally drained. If the Nook turns itself on during this process manually turn it off. The battery charges faster and more deeply if it\'s truely powered down. Charging more than 3 hours won\'t hurt it. In fact some manufacturers claim leaving thier products on charge for an additional hour after the charging light glows green is good as it leaves a slightly deeper charge on the battery. Also I believe leaving it alone for that hour allows it to cool the battery. Most manufacturers also recommend tottaly draining the battery at least once a month and then fully recharging it 1+ hours after charging light is green. They claim this helps the battery maintain a healthy charge and extends the battery life. Simply disconnect any charging cables, turn the unit on and just let it set. Don\'t touch it peroid just leave it alone until it turns off because the battery is totally drained. Then just plug it in and leave it. Only if the unit automatically turns itself on do you manually turn it back off.
Well that\'s about in in keeping the battery life and charge at its maximum.
If your AC power adapter has gone south there are only three ways to get around this. 1. Purchase a generic AC to USB adapter. 2. Purchase a genetic DC to USB adapter. Most of these can be cheaply purchased at most drug stores ect.. these days. You can even get DC to USB ones at dollar stores such as Dollar Tree. Good way to maintain your battery if your AC one goes south or you lose house current.
One other way to charge your battery is to plug the USB cable into your computer. Some manufacturers don\'t recommend this as this more often than not doesn\'t fully tank up your battery.
You can also get replacement charging cables at the same place you got the adapters. Places such as Walgreens, or CVS often have these at around five dollars a pop.
Apr 26, 2014 | NOOK HD 7 Tablet
Android tablet problems
Try going to system settings and select 'About Tablet' then checking you are fully charged and in good wifi signal select 'system updates' Update to any new version it finds.
Make sure it is fully charged with the screen brightness down (so it will last for hours, just in case). The last thing you want is a power down during an update...
Jun 05, 2013 | XO Vision Ematic eGlide 7Inch Touch Screen...
Coby Kryos Android Tablet is not charging. It is connected to a charger but its not charging.
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
May 21, 2013 | Tablets & eReaders
AgpTek android 4g tablet charger doesn't charge my tablet !
This solution worked for about a couple of months, but now I'm looking for a replacement power supply also. I wiggled the tiny adapter plug while it was inserted in the tablet and found that it would make contact at a certain angle and pressure. So I got a long fat rubberband and used it to make proper contact by rigging it diagonally, across the tablet. Be careful as too much lateral pressure will bend the plastic sleeve of the contact and render it useless. My theory is that the original problem was partially caused by using the tablet while charging and thus damaging the plug. Although this is a persistent complaint / problem with AGPteK tablets. Mine didn't even last 6 months.
Dec 25, 2012 | Brainydeal Agptek 7" 1.2 Ghz Tablet Pc 4gb...
How to discharge battery
"Calibrating" a laptop battery is one way to increase the lifespan of a battery that doesn't last long. The procedure involves two steps: fully discharging the battery, then then fully charging it immediately thereafter. It's important to note that a full discharge doesn't mean you drain your battery until your computer powers off, but rather that you deplete it until it reaches a level of approximately 3 percent capacity, according to BatteryCare.com.
1. Charge the laptop battery to 100 percent. Allow the laptop to sit plugged-in and fully-charged for approximately two hours.
2. Click the "Battery" icon in the lower, right corner of the Windows Taskbar and click "More Power Options." Click "Change When the Computer Sleeps," then click "Change Advanced Power Settings."
3. Scroll down to "Battery" and click the "Plus Sign" icon next to it. Click "Critical Battery Level," then click the arrow to decrease the number to "3." Click "Apply," then click "OK."
4. Unplug your laptop and continue using the computer until it reaches 3 percent, at which point it hibernates automatically. Allow the computer to hibernate for at least five hours, then plug it in and allow it to recharge fully.
I hope you find it very helpful. Thank you for using fixya.
Aug 17, 2011 | eMachines eM3502074 Tablet PC
I just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
May 13, 2011 | PANDIGITAL Digital Book 843967071153...
Google Android 4.0 7 inch 1080P Video Capacitive Screen 16GB Tablet PC Logo
41 people viewed this question
Top Google Android Tablets & eReaders Experts
 Mike M
Mike M
Dayton Computer
Dayton Computer
Sammi James
Are you a Google Android Tablet and eReader Expert? Answer questions, earn points and help others
