DianPenChe petrol pump in the tank, you want to change you must remove the fuel tank in the oil pump and there are two issue: 1 in the oil pump assembly, oil pump's called shell connected in, 4 s shops and rich in method, fast, simple, inexpensive, 500 piece count in the conscience. 2 in the pump core, open the cover of the oil pump assembly, is in the inside of the pump (pump), the full package instead of 100 pieces. Oil pump is bad bad pump core, assembly is a bigger plastic shell as a support, the pump core is fixed to live.
autodiagnostic tool
SOURCE: I have a 93 pajero exceed . Turns over but no
The fuel pump would have nothing to do with spark. A scan of the computer should reveal the problem area--suspect either a bad crankshaft or camshaft sensor. You could also have problems in the ignition system itself. Good luck!
