Did a system recovery once then kept getting blue screen memory dump. then windows did come up and was installing some elements but then crashed again now screen comes up to repair windows or start normal. when pick repair wants a windows repair disc that was not sent with this netbook. tried to do system recovery again cannot even do that just get the repair windows or start normal screen.
You should start windows in safe mode. By pressing the F8 key right when Windows starts, usually right after you hear your computer beep when you reboot it, you will be brought to a menu where you can choose to boot into safe mode. If it does not work on the first try, reboot and try again as you have to be quick when you press it. when it starts in safe mode, run system restore and when prompted for a restore date, choose an older restore date, probably one you a sure was perfect 2 days before the blue screen issue. This should get your system running in good shape.
SOURCE: driver_irql_not_less_or_equal on windows 7 netbook
This dump occur when driver of the hardware is not accurate. Boot system in Safe Mode and uninstall driver which you installed last time. If you unable to enter safe mode, then you need to install a fresh copy of windows, then install proper drivers from Acer's official support site.
Regards;
Hasan
SOURCE: blue screen of death comes up then the netbook turns off
This article may help you....or these.
If you can turn off the auto restart to get a stop error code from the blue screen, that will help you to diagnose this error. See 'disabling restart..." here. Then reboot and note the exact error code reported. Write back with that info and we'll help you to sort it out.
You can look up codes here.
Also helpful links for blue screens here, here, & here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: ACER ASPIRE 3680 WINDOWS ERROR RECOVERY
hi
you said u did try to press F2 or F8 to get to bios setting, are you saying pressing these would not open bios setting windows?
shakeel
SOURCE: Acer Aspire 5520 screen and NVIDIA driver problems
its a hardware issue, and why its your motherboard on laptop have a problem, not physically but i think your try to re-update your BIOS to clear out all the malfunction chips inside your laptop. This problem was actually i encountered before but no one also understand why is always came back the problem on it. Go to the website on the ACER www.acer.com to download the latest BIOS updates on it.
You should install it one by one or step by step like for example 1.0 then 2.0, like that. And don't be so hurry the BIOS is a very delicate setup rather than Windows System.
Basically restore the BIOS setting on default after that installation.
This installation might help to you with that problem and dont forget to unplug all unnecessary input devices so that it will not hang up again. Afterwards run Disc Recovery Disk to setup Windows System, good luck! Bboy
SOURCE: my acer netbook crashed.. 2nd time to happen.. i
Technically when your system crashed it's not easy to put it back again with details to details instruction, even guide cannot help out to that.
Maybe your Netbook have another problem aside on system crashing.
So it's difficult to say you can fix it in your own way.
Call a technician and ask after he fix it. I'm sure he will tell you and how to manage it.
Hope this tip might help you.
Oh and I did try the safe mode etc still comes out the same.
can't download anything how do you do that when you cannot get the windows screen to come up?
Ok finally trashed the thing because the screen would not work anymore think my son got his money's worth out of the thing would have cost more money to fix than get a new one...so i think i still have the drive in a box somewhere just in case.... Thanks for everyone that tried to help.
