Cars & Trucks Logo
Anonymous Posted on Mar 24, 2013
Hi a1999 E 320 CDI started with the help of a push of the fuel pedal for the first time after replacing fuel and oil filter and wouldn't start for the next few times. And I discovered the new fuel
Diesel fuel filter changed but won't start even if I put back the old one. Please help. Thanx
Anonymous
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Mar 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
33
Questions
Helped
7649
Points
91
If it ran ok before you changed the fuel filter you may have lost prime and may have to bleed the injectors
  • Anonymous Mar 24, 2013
    I don't drive it much. But it run well & did 250km few days ago so.. Can u please explain to me when u said " I MAY HAVE LOST PRIME "? Many thanks
5 Related Answers
Anonymous
  • Posted on Jun 14, 2009
SOURCE: replaced fuel filter and PCV Valve. Won't start.
check air filter , crank engine to see if u have suction if u dont its the timebelt if u have suction , and replaced fuel filter and pump , check spark to plugs
Anonymous
  • 2418 Answers
  • Posted on Jul 28, 2009
SOURCE: 2004 Ford F350 diesel, changed fuel filters hard starting
Pull the filters and ck for plastic or o-ring in wrong place. Something is up in the filter.
Anonymous
  • 1111 Answers
  • Posted on Jan 04, 2010
SOURCE: 1995 gmc jimmy-won't accelerate wants to stall
could be the fuel pump ...you will need to do a fuel pressure test on it ..the pressure should be 63 anything lower even so much as a few lbs will cause this to happen ...as well if it sat that long i would consider a complete tune up and check all vacuum lines for dry-rot
GARY TOOP
  • 22 Answers
  • Posted on May 31, 2011
SOURCE: hi my peugeot boxer 2007
The oil light flashing on your 2007 boxer 2.2 hdi is a service due indicator. will need resetting with compatible diagnostic equipment.
jturcotte
Jeffrey Turcotte
  • 8991 Answers
  • Posted on Sep 14, 2011
SOURCE: I have a 1996 Plymouth Breeze... That won't start,
Hi, this sounds like a bad fuel pump. I would have the fuel pressure checked. Sometimes Autozone will let you borrow a fuel pressure gauge to check your fuel pressure. Just unscrew the cover from the pressure port on the fuel rail and screw on the pressure gauge. Put a rag over your hand while screwing it on to avoid getting fuel sprayed around. Lay the gauge in a safe place and start the car. Read the gauge, record the reading, turn the car off and remove the gauge. If the pressure is less than 35 psi, you need a new fuel pump. Please let me know if you have questions, and thanks for using FixYa.
1995 buick lasbre stalling when i touch the gas pedal, change the mass airflow sensor, fuel pump and filter, rely, and regualtor, now the pcv now it doesnt start at all i need help can anyone help me...
omg you did everything except the air filter. yours is most likely clogged or really dirty. I wouldn\'t drive it anymore until you get them. you can destroy your engine with a dirty air filter. not breathing. also if you drive your car on empty a lot your in for a lot of time and money. all the sediment from gas sits at the bottom of the tank and when you use the last of the gas your engine is forced to suck up debris. thus clogging your fuel lines and you wont be able to drive at all. or even start if it gets bad enough. you will have to get your fuel lines flushed or replaced. doing it yourself is impossible. always good to drive with over quarter tank all the time. or your engines doomed.
I have a 2001 buick regal ls, the problem I'm
Have a look for a hole in the block where the oil is coming from. If you have one you have blown a motor.
1helpful
2answers
Car ran fine shut it off came back it didn't want to start. started went about half a mile sputered an died wouldn't start back up 1991 subaru loyal wagon
Hi sounds like the typical fuel pump or filter problem with these cars, best way to tell is take top fuel hose off on fuel filter under hood, turn key on ignition (not start) and fuel should pump out, if not its your pump, just beware of doing when engine is hot
Okay where to start, my 2000 Ford Focus has been a nightmare this last month of owning it. I will bypass all of the other problems that its had so I can figure out my most immediate need. Whats been...
Hi, I would take it to a mechanic and get the stored computer codes, which should narrow the problem down to 1 thing. Have you replaced the fuel pump and filter?Do something for me, try to start the car in the morning but when you crank it over push the gas pedal to the floor. If it doesn't start it could be a fuel pump problem. Good luck.
2answers
1998 chev 1500 hard starting when cold but starts fine after warming up changed plugs and sensors
The first thing i would tey is changeing the fuel filter. Chevy has a problem with the design from the fuel pump to the fuel inlet on the intake manifold. What they did it is back up the power supply to the fuel pump from the fuel relay and split the curicut and ran the back up through the oil pressure sending unit . So even if the relay went bad while driveing the fuel pump would still get power and the truck wouldn't die on the road its a saftey thing .But if the relay is bad then the engine needs to build up enough oil pressure to trip the oil sending unit to send power to the pump from cranking thus a long cranking time when cold . Change the fuel filter first it should be replaced every 4 to 5 years anyway . A nd if that dosn't fix it try the relay it should be behind a panal inside the glove box on your truck and if that dosn't work replace the oil pressure sending unit. One of these 3 things should work if the fuel pump is working correctly
1helpful
Why a have push the gas pedal to start if I don't
YOU NEED A TUNE UP.REPLACE SPARK PLUGS AND WIRES, REPLACE AIR FILTER AND FUEL FILTER,CLEAN FUEL INJECTORS USE CAN OF SEAFOAM POUR IN FUEL TANK.FUEL TANK CAN HAVE 3/4 TO FULL TANK OF GAS.SEAFOAM WILL FLUSH OUT CARBON ON TIPS OF FUEL INJECTORS SO THEY CAN SPRAY WIDE NORMAL SPRAY.
THE OTHER DAY COMMING HOME FROM WORK MY CAR DIDN'T WANT TO GO. THE MORE I PUSHED THE GAS PEDAL THE LESS POWER I HAD. IT SOUNDED LIKE IT WAS BOGGING OUT OR SOMETHING. PUT MORE GAS IN IT. THOUGHT...
change your fuel filter seeing that you may have ran the tank right down it may be cloged it may me a good idea to service the hold fuel system, injectors, throttle body, lines, tank,filter.
2answers
Changed Fuel Filter with full service but engine not turning on
hello,if your old fuel filter is not dirty,install your fuel filter,sometimes fuel filter is defect even it"s new,hoping there is no fuel leak during your replacement of filter,ty
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
