Vita Spa Error code (PB) is a power board communication error. Turn off the power and then check the connection between the topside control and control box. check for loose or unplugged wires, unplug the topside control (after turning off the power) and check for signs of shorts or charring on the wiring ribbon/connectors. If you cannot find the source of the problem you will need to contact your dealer or repair technician. I hope this helps =)
This might be a problem with the topside control. When the spa is clicking, try unplugging the topside control and see whether or not the problem stops. If the jet button is stuck on the topside, the pump will turn on-off-on-off-on-off until the topside is unplugged.
Your question is a little confusing ... chain saw networks?
I believe you want to know how to build a wired computer network ...
You will need special tools to do this including a RJ-45 crimp tool. You should use the highest quality ethernet, 'Cat 5', Cat 5e', wire available to you. On the ends you will install RJ-45 connectors (8 conductor 'plugs'. Choose and stick with one of the several color codes for placing the conductors into the RJ-45. Color code guide should come with your special tool. Make sure the ends are in proper order, trimed square and inserted fully into the connector before you crimp. Purchase a test tool to verify your work. Expect to pay $50.00 US or more for the testing tool. Cable, connectors, wire, router or switch and other hardware should be available where communications or electrial supplies are sold.
Either your wallmount is not correctly crimmped according to the standards or your cable is not correctly crimmped according to the standards. So its better you crimp the cable and fix the R.J 45 connector in the sequence given herewith.colour coding of the cable:-
1-oranage white
2-orange
3-White green
4-Blue
5- White blue
6-Green
7-White brown
8-Brown
The same Sequence should be at the wallmount and at the R.J 45 connector.
Some testers do not test ALL the wires. Some will only test pair 1 and 2. You may want to use a DVM (Digital Voltmeter) set on the ohms function and check continuity on each of the eight wires from RJ-45 to RJ-45 connector or use a cable tester that will check all the wires. If you use a DVM check 1 to 1, 2 to 2 etc. for continuity. Good will read 0 ohms, open will read infinity or OL on some meters. 90% of all cable problems are poorly crimped or broken wires at the RJ-45 connector. It is difficult to be sure which end has the bad connection so you may need to change BOTH RJ-45 connectors. Do one, then check the cable, if it doesn't work, do the other one. It is a 50-50 shot. I prefer and encourage the rewiring color code using the EIA 568A standard. Starting at pin 1 the color code would be orange-white, orange, green-white, blue, blue-white, green, brown-white, brown. You don't have to do it that way, but you must make sure that the same color wire is on the same pin on each connector. If all else fails, you can go to you neighborhood computer shop for help in installing connectors. It takes a lot of practice to do it right. Hope this helps
