I also have a Toshiba 1360, I had some cleaning blades dry-rotted and some peace damaged the Drum. I was able to find the replacement parts. After I installed them then I had the C7 error code I was able to clear that. Thanks to some of the post I read here. Now I have Ad error code. Does anyone happen to know what that means? Thank you a head of time!
SOURCE: Toshiba 1360 C7 code. How expensive is it ti fix
With the unit off hold down clear/stop and 8, ad should apear push 89 start (display will read 03) then 0 start. tis should fix it. -Carl
SOURCE: Toshiba 1360 C7 Error Code
TOSHIBA
1310
C7
Fusing unit warm-up error, defective thermistor, fusing lamp or thermofuse
The codes are good for several models.
SOURCE: toshiba 1360 copier
Turn it on holding down 0 and 8. Key in 89, press start. press 0, press start. Turn it off and on.
Did you replace the cleanerblade?
Power off the machine, switch on while pressing 0 & 8, enter 200, then press the start button, the machine will run for about three minutes to adjust the Toner sensor. The machine will stop, press the interupt button to save the setting, switch off and then on.
If the older techies is reading this, please help to confirm.
