On bottom of coffeepot Date code #012709. When making coffee water leaked out behind the filter holder about 1" from water cyclinder. Instead of 8 cups it made about 6 cups for 3 or 4 days. This morning the cyclinder of water is cold and the heat button would not turn on. The coffeemaker just quit working. There are no problems with the electric in the home.
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
SOURCE: Bunn Coffee Maker Leaks out the bottom
Hi I have had this problem twice....this time I took off the top of the maker to check it out and noticed something loose and this fixed the problem, on mine at least. Lift the lid and take out the two Phillips screws, and remove the grid. Take out the three (or four) Phillips screws on this level and remove the top of the maker. There is a tube, with a hex nut around it, under the swivel arm that shuts off the water when the lid is up. On my maker this nut was very loose, even though the seals were still good. I tightened it with a pair of pliers( don't over tighten) and it hasn't leaked since. I also cleaned the water tray out while I was at it , as it looked rather yechhy. Reassemble and put the screws back in (don't over tighten, as they are in plastic)
SOURCE: My Survival Guide To The Dreaded Err2 Disaster
Well, I am not happy to read that we need a new coffee pot since this WAS the new coffee pot we bought to replace the last one that up and stopped making coffee. Yes, this coffee pot is less than two months old! Err2 means we need a new coffee pot? It won't be a KitchenAid!!!!!!!!!!!!!!! We want our money back!!!!!!
SOURCE: Bunn 10 cup home coffee brewer is leaking from the
These models have a plastic pour-in tray just under the top lid. The plastic on these trays gets brittle over time with the heating and cooling, and they crack where they mount to the tank. The only real way to repair this is to replace the pour-in tray, but these are not sold anywhere that I have found. You might be able to find a used one at a Bunn dealer in your area.
I have seen some people do a temporary repair by putting a washer under the mounting bolt and sealing it with silicone, but this is a temp. fix at best. By the way, the reason that the water appears to be coming from the bottom of the machine is that there is no other place for the water to come out after it leaks from the top.
