Video Game Consoles & Games Logo
Posted on Mar 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Graphic card related
I have graphic card ATI radeon RX 550 .I have recently installed prince of persia 2009 but during installation its showing that you need shader 3 for the game to run.Pls provide a solution other than upgrading the graphic card
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Have you updated your graphics card with the latest drivers?
Anonymous
Level 3:
  • Master 408 Answers
  • Posted on Mar 02, 2009
Anonymous
Master
Level 3:
Answers
408
Questions
6
Helped
148728
Points
1141
I don't think there is a solution other than replacing your graphics card.  The RX550 does not support it. It only support 2.0.
Features
  • Powered by the most powerful GPU- ATI Radeon X550
  • Four parallel 3D pixel pipelines
  • Two programmable vertex shader pipelines
  • PCI Express X16 lane native support
  • Full DX9 support
  • SMARTSHADER 2.0
  • SMOOTHVISION 2.1
  • Add Your Answer
    I have purchased a asus p5g41c-mlx motherboard on jauary 2011 .but after 2 month its grahpics not work properly ,it is flickering ,i have using window xp. i have uninstal the grahpics and reinstal it but...
    Hello there,
    Here is *********** boards VGA details.
    Integrated Intel GMA X4500 graphics Maximum shared memory of 1GB
    Supports RGB with max. resolution 2048 x 1536 (@75Hz)
    Supports Microsoft® DirectX® 10
    Here are the system requirements of the games you are currently playing with problem.
    NFS Most Wanted- It should run with no problems just avoid high detail settings.
    Minimum: 32MB or more, ATI 7500 or greater; ATI Radeon Xpress 200; NVIDIA GeForce2 MX/GTS or greater Recomended: NVidia 5900 or ATi 9800 with 256mb of video memory
    Prince of Persia Two Thrones
    Minimum: 64MB Recomended: better than recommended in NFS Most Wanted
    COD Black Ops
    Minimum: Shader 3.0, 256MB GeForce 8600GT/ ATI X1950 Pro or better. Recommended Nvidia: GT 240 or higher Recommends Ati: HD 4670 512MB or higher Minimum Memory: 2GB
    Some games have hardware validation test if your unit fails to the requirements you cannot install the game. try to download this BurnIn. Select the 32bit Standard edition. install the utility and stress your x4500 graphics. Sir you did not post your Processor and Memory. The x4500 graphics will use 128MB of your ram, If you are using 1GB or 1024MB - 128MB = 896MB. 2GB or 2048MB - 128MB = 1920MB. For Memory system requirements your system failed and the main problem is your video card.
    Hopefully this helps.
    Thank you for using FixYa.
    1helpful
    My HIS Radeon x1650XT hangs after playing 3D Games.
    change your graphics card or you may upgrade your card.
    2answers
    Direct X Problem !
    go to the direct x website and download the latest direct X version
    Computer restarts on game start
    Remove all traces of ATI drivers from add/remove programs and reboot before trying to install the newest Catalyst Control Center. The latest - 9.4 - does NOT have your card listed (they list the PCIe version, not AGP).
    Recently ATI removed support for many of their "legacy" cards. 9.3 may be of more use to you.
    Someone Pls. help
    You need to install drivers. go to ati.com and get current drivers.
    2answers
    Driver is not working
    strange... even WinXP has got the drivers for that ATI AGP card.
    18helpful
    ATI Radeon 9550 (RV350) 3D Accelerator
    Radeon 9550 series.: http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
    Download the Catalyst Software Suite Driver & CCC. You will find a ton of control within the Catalyst Control Center.
    Remove any ATI software before installing the newer combo.
    If you get a error during uninstall through the control panel run ATI's uninstaller at.:
    http://searchna.ati.com/promosearch/?site=us-en&la=en&qt=cat-uninstaller&selectsite=ATI&sp_a=sp10039240&sp_p=all&sp-x-1=col&sp_f=ISO-8859-1&sp_q=cat-uninstaller&Search.x=9&Search.y=8
    2helpful
    2answers
    ATI Radeon mobility Graphics Card 9200 Drivers for VISTA
    http://www.opendrivers.com/driver/240370/ati-radeon-graphics-card-driver-catalyst-7.11-windows-vista-x32-english-free-download.html
    Top Video Game Consoles & Games Experts
    MegaByteMe
    MegaByteMe
    Aron
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
