Question about La Crosse Projection Alarm Clock with Temperature and Humidity Display
Where to put outside remote
I have a Shift 3 time & temp radio and don't know where I can put the outside remote because it says it can't get wet. Where could this be put so it works?
  • Bren stephen Feb 25, 2019
    Put it up high on house if you have a overhang, put the remote in a zippered plastic bag.. like zip lock
If you have storm windows, put it between the window and the storm window.
Or try just below the overhang of your house.
Posted on Mar 16, 2009
SOURCE:
MODEL WMR80 / WMR80A
1. Take the cover off the back of the remote sensor.
2. Set the chanel to ch.1. (I tried all three but only ch.1 worked for me).
3. Use a stick, needle, what ever you can (but you need two) and hold down the reset button on both the sensor and the clock at the same time.)
If done right, it should only take a few seconds to start.
The outside temp is delayed at first. Be patient.
Oct 09, 2013 | Oregon Scientific Lwb0997110113004...
Oregon scientific IWA 80055 Outside temp won't display and I have replaced the batteries on the sending unit and it blinks two times every few seconds.
I have the same unit (IWA-80055) and after not finding anything helpful on the net, I just messed with it until I got it fixed. Here's what to do:
3. Use several tools. (i.e. a stick, needle, what ever you can but you need two) and hold down the reset button on both the sensor and the clock. (at the same time.)
Jan 31, 2010 | Oregon Scientific Lwb0997110113004...
Remote signal not received by Shift 3 projection alarm clock
1) Does the remote have batteries? See other posts that describe how to do this (4 screws in back need to be removed). Temperature should be displayed in small window of the sending unit if it's working.
2) Hold Channel button for 3 seconds until it beeps - the unit then searches for a signal.
Aug 02, 2009 | La Crosse Projection Alarm Clock with...
Remote that gives outside temp does not work put in new batteries, still does not work!
Pull the batteries out of the clock, wait a minute, and then put them back in. That will reset the link between the two. The temperature should be OK in just a few minutes. The clock will read the wrong time and date until it resets during the night. The next day, all will be well.
Apr 20, 2009 | La Crosse Radio Controlled Atomic Clock
Shift 3 projection alarm clock cannot connect with the remote
Did you put two AAA batteries in the remote? Use a small phillips to take the cover off of it. Then hold channel on the main unit for three seconds to synch it with the remote.
Mar 14, 2009 | La Crosse Projection Alarm Clock with...
Shift 3 Projection Alarm clock remote cannot open
Once the batteries are installed in the remote the temp will appear in the LED screen. Now you are ready to link signals between the main unit and the remote. Simply remove one of the two triple A batteries from the main unit and then replace. You should then see what appears to be a flashing object shaped like a kite with a tail while the two units link up. Then you should see the temp reading at the remote appear in the LED readout at the main unit. By the way there is also a very small reset at the top of the switches on the back of the main unit that can be depressed with a SMALL pointed object like a scissor point or safety pin point.
Feb 06, 2009 | La Crosse Projection Alarm Clock with...
Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Dec 30, 2008 | Oregon Scientific Lwb0997110113004...
Cant get outside time to work???
I have the same problem with mine. The outside temp displays OK for a while, then it displays two dashs. I unplug the main unit from the wall until the outside temp comes back. I then plug it back in and it works OK. I found that if the remote sensor is located more than 40 ft from the main unit and there are a couple of walls between the two, the outside temp fails more often. I have noticed that putting my wireless phone in it's charging craddle can cause the radio or nature sounds to turn on. I moved the main unit further away from the phone and that cured the problem. Sometimes it will do this if the humidity is low and I build up a static charge and then touch the unit.
Jan 04, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
La Crosse Projection Alarm Clock with Temperature and Humidity Display Logo
224 people viewed this question
Top La Crosse Audio Players & Recorders Experts
Steve Allison
Steve Allison
Are you a La Crosse Audio Player and Recorder Expert? Answer questions, earn points and help others
