Remove the recoil cover and check the coil for proper gap (use a buisines card between tne coil and the magnets on the flywheel it should be snug but not to snug you cant get the card in between) if that is to tight you will have to adjust it, if it is ok than disconnect the ground wire and check for spark, if still no spark than your coil is no good, if you have spark than check the ground wire for a bare spot cause it is grounding out some where. also check the throttle shut off wire that it is not contacting metal when throttle is up and if it has a key that the wire there isn't cotacting metal also. Please let me know how you make out and if we have to check further.
