Televison & Video Logo
Posted on Mar 01, 2009
At power up tv displays Acer logo then goes to black
- product is an Acer AT3201W LCD TV 32"
- at power up flashes Acer logo for a second then goes to black
- green power light stays on
- sound is okay
  • 2 more comments
  • sishodin Mar 01, 2009
    - could still turn off/on with remote or panel button
    - unplugged to 'reset' but problem persists
  • Anonymous Mar 09, 2009
    same problem and mine was the controller board
  • Pepouzze Apr 23, 2009
    The tv working 10minut and soudainly the screen become black and the sound work, and at power up tv displays Acer logo then goes to black
    after few minutes of working the screen become black and the sound working.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1387
Points
8
Will not turn off power with out unplugin it
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
1helpful
How do i repair acer flat screen tv model At3201W that turns on When goes black
Back-light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Can't get rid of LED TV logo on Samsung TV
Apparently it's on demo-mode so you have to go to 1. Set up 2. Plug and play 3. Then change to home instead of demo
2answers
I have a TDA-03211C Polaroid TV. It powers on, shows the logo for less then a second, goes black, then flashes the cable channel and goes black again. No response from the control panel, and the power...
The power supply board have more than just two capacitors problems,could be anythings else like a diode,transistor or those transformers on the power suuply board,u have no trouble shooting skills or tv repair experience,will never figure it out.Tries websites like Shopjimmy.con,Ebay.com to buy a whole refurbish power suply board for the replacement.
My lcd Tv Acer AT3201W made a loud pop which caused the circuit breaker to trip I no get no power to the tv
The tv power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
3helpful
4answers
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
