Precor Efx-5.33 Elliptical Machine Cross-trainer Fitness Exercise Equipment 833 Logo
Anonymous Posted on Mar 23, 2013
MY EFX SAYS ERROR 30 WHAT WRONG WITH IT
I CANT SEE HOW MANY CALORIES I HAVE BURNED NOTHING IT JUST SAY ERROR 30
  • Anonymous Mar 23, 2013
    THIS IS NOT HELPING ME WHAT IS THE SOLUTION WHAT WRONG With the ellipitical machine
ernesto cuadra
Level 3:
Top Expert:
  • Precor Master 12,223 Answers
  • Posted on Mar 23, 2013
ernesto cuadra
Precor Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4076185
Points
34431
Errors 30 through 33 all indicate the loss of communications or erratic communications betweenthe microprocessors in the upper PCA and the lower PCA. The trouble shooting procedures forall of the are essentially the same. Error 30 is defined as upper PCA not receiving from lowerPCA. Error 31 is defined as faulty data received from lower PCA. Error 32 is defined as lowerPCA not receiving from upper PCA. Error 33 is defined as faulty data received from upper PCAPossible Causes1. An upper PCA to lower PCA interconnect cable is bad.2. The interconnect cable at the upper PCA was mistakenly plugged into the CSAFE connector.3. A 5.17 EFX equipped with version 1.01 upper and lower software.4. A 5.17 with mismatched upper and lower software.5. A defective lower PCA.6. A defective upper PCA.Possible Remedies1. Substitute a know good interconnect cable between the upper and lower PCAs to determineif the interconnect cable is defective.2. Remove the interconnect cable from the CSAFE connector and insert it in the correct upperPCA connector.3. Replace the 5.17 upper and lower software with the most current software versions.4. If only one of the upper or lower software is version 1.01, replace the version 1.01 softwarewith the most current version of software.5. Substitute a known good lower PCA to determine if the lower PCA is defective.6. Substitute a known good upper PCA determine if the upper PCAs defective.
What is some tips of burn calories with a spin bike?
You cannot go wrong with spinning your Bike at the gym. Not only are or stationary bikes better for all fitness levels, but they are also the ideal tool for finishing daily exercise targets. In fact, you can Spin Your Bike 30-45 minutes workout that can burn 300 or more calories, depending on concentration and strength.
Steps do not reset at end of day
Try to perform a reset of the Fitbit. Follow
How do restart my tracker
When does my tracker reset and what happens to the previous day data
Your tracker resets your data to zero each night at midnight. For most trackers, your minute-to-minute data will be stored in your tracker for up to seven days without syncing. If you have a Fitbit Alta™ your minute-to-minute data is stored for up to five days. A daily summary of your activity is stored for up to 30 days.
Keep in mind that your calorie burn estimate will begin each night at midnight, so if you're up late and moving around, your tracker will adjust your calorie burn accordingly. Even if you are asleep at midnight, you will still see that you've burned some calories upon waking up in the morning. This is because you still burn calories even if you are sedentary or sleeping. Fitbit calculates your calorie burn based on information about your age, gender, height and weight.
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
How do I reset the time on my watch
As well as tracking calories burned through activity your fitbit also tracks your BMR calories. These are the calories you burn just keeping your body alive (even when asleep). They are calculated from your profile settings for age, height, weight etc so you needn't be wearing your fitbit to get them. What you are seeing in the morning includes the total BMR calories burned since they reset to zero at midnight.
Unfortunately, there isn't a way to reset calories during the day or to exclude BMR calories from your calorie stats.
My precor efx 544 has stopped recognising that i am using it. does not display strides or calories burned. any ideas?
My Precor Elliptical EFX 546 Timer Stops After 7 Seconds, what is wrong? The most common cause for the Timer to Stop After 7 Seconds on a Precor Elliptical is NO RPM Feedback.
Knowing the status of the unit from its last use as well as the last service or part replacement is a great place to start.
Check the connection of the speed sensor to the lower board. Reset connection if necessary.
Check the magnet. The magnet is located on the user's right crank arm on versions 1 and 2 and the user's left on version 3. The magnet passes the speed sensor with each revolution of the crank arm. The magnet should be installed so that its south pole is facing the speed sensor. You can check the magnet polarity with another magnet that has marked poles or a compass. The north pole of the marked magnet or the south facing needle should be attracted to the magnet. Correct magnet installtion if necessary.
You may also check the spacing of the speed sensor to the magnet. The spacing should be 1/8" to 1/4". Adjust if necessary.
Also see the following link for additional information.
Replaced Crank Arm on Precor EFX 546 and Display Doesn Work
The Reebok Fitwatch 10S Calorie Counter
Yes when you are in time mode press the mode button 5 times this will be your calorie screen press the st/stp button to activate the calorie counter you will see in the bottom left corner it says CA ( meaning calories) and in the bottom right crn are the calories you are burning press the st/stp button again to stop then reset when you want to start again.Hope this helps can you help me? I keep pressing the sensor buttons and my heart rate does not appear what am I doing wrong ? Ive read my instructios inside out even returned the watch and got another but the same thing keeps happening ! Initial when I set the watch up it works then I just cant seem to get my heart rate to appear ????????? Thanks Nicole
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
