Not working have reset have turned full revoloutions still hums when turned on but does not work
Copy following link for troubleshoot walk-thru:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Check that unit is receiving 80% rated voltage
Humming sound means start capacitor has gone bad.
Replace disposal.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: humming noise when turn on insinkerator badger 5XP
Your disposal is stuck. Sounds like something either fell in it, or perhaps a bone got inadvertantly tossed in. Do you own an allen wrench set? The garbage disposal did originally come with one, but it usually gets lost. The one that came with it will look like two hockey stick stuck together. In any event, you need one for the fix. There is a hole on the bottom of the disposal, directly in the center. Find the correct size allen wrench and place in this hole. Twist clockwise and counter clockwise until it is free. Once this is done, you most likely will need to hit the reset button on the bottom. Good luck!
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
