LCD Broken - Cannot Access Phone Through PC Companion due to Pattern Lock
SOURCE: pattern lock on sony ericsson xperia x10i need
*Turn off the phone
*take off battery & put back in
*press and hold down the right & left silver buttons just under the screen
*with stylus press in the hole on the right side of battery
*after 10Sec you will be prompted to press the R key
*If successful press the space key to finalize changes
www.usedcellphoneshop.com
SOURCE: my sony ericsson xperia x10i
patern is locked and i must open with google account but phone dont accept tha email and pasw what can i do ?
SOURCE: hello, i have sony ericsson
Watch the following video on the instructions how to unlock your phone:
http://www.youtube.com/watch?v=dec8fUlJkac&feature=player_embedded
If the solution works for you, please rate.
Thank you
SOURCE: hi, i had a sony
Hi, You can get the unlock code and instructions through online. only you should give your IMEI number and get the unlockcode for your mobile. You can also get the IMEI number by entering this on yourphone *#06# It will then display your IMEI number and you may alsoget a unique global serial number. Your IMEI number should be 15 digits. There are so many software can help unlock, you can download from bellow link, http://www.top4download.com/free-nokia-unlock/ or Step by step guide http://www.unlockme.co.uk/unlockme.html NokiaFREE unlock codes calculator for windows allow to useyour mobile phone with any service provider around the world. Repair, remove sim restrictions and unlock Nokia, Samsung,Siemens, Maxon, NEC, Sony, Panasonic, Vitel, AEG / Telital, Alcatel cellphones. How to use: You only need to enter IMEI, to get IMEI numeryou must press *#06# at your mobile phone keyboard and enter. To unlock nokia mobilephones you should select the operator company where you bought your cellphone orwhere your cellphone is locked. DOWNLOAD LINK http://download.cnet.com/NokiaFree-Unlock-Codes-Calculator/3000-10440_4-10318195.html OR http://www.topshareware.com/download.aspx?id=42084&p=&url=http://unlock.nokiafree.org/NokiaFREE_v310_Nokia_unlock_codes_calculator.zip 1. Install >2.start>3.prograame 4.>Nokia free calculator>5.lclick >6.insert your office xp in cd tray(If the front page not installed) 7. Seclect company 8. model 9. Type IMEI,no 10. Country 11. Name sim provider (Hutchison) 12 Go step by step !3 .AFTER SELECT ALL JUST CLICK ON CALCULATE You can see you unlock no right side and copy for your mobile. IF YOU THINK IT IS CRITICAL TAKE A HELP BY ANTHER You can take the help through bellow link. http://unlock-zone.com/ This website for unlocking your mobile .There are so manywebsite for unlock mobile, \but it is recommended by mobile forums. This side is reallyperfect. Only you need to wait few minutes.. Hope this helps. Thanks for using fixya .
SOURCE: PATTERN LOCK ON SONY ERICSSON XPERIA X10i
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
