My John Deere 2354hv moves slow in forward evenb slower in reverse
SOURCE: my John deere l118 riding mower goes slower and
Firstly remove the battery and battery tray and clean all grass and debris from around the hydrostatic drive and cooling fan. Secondly check the drive belt idler pulley, arm and spring for free travel. Hope this helps, regards Phil.
SOURCE: john deere 300 garden tractor will not go forward or backwards
Make sure the neutral lever (rod) back by the right rear tire is pushed ALL the way in.
SOURCE: our john deere sabre 17.542 hs ride on mower will
If traction drive belt is turning you should check the input drive shaft on top of trans to see if it is turning as well,Traction drive belt is suspect but could be a stripped out input shaft pulley.Make sure the machine tow lever is not pulled out,rear of machine by tow hitch.Also pull rubber caps off of both axle ends to see if one the axles is turning free inside of rim,if so remove wheel and replace axle key.
SOURCE: forward/reverse lever not holding in position on
Some come with a tension bushing underneath on linkage. Check that first
SOURCE: my john deere 316 stopped moving forward and
HAVE YOU CHECKED THE TRANSMISSION/HYDRAULIC
OIL? THEY ARE THE SAME. ON SOME TRACTORS THIS
CAN BE CHECKED AT THE REAR OF THE TRACTOR JUST
BELOW THE SEAT. IT COULD ALSO BE A BAD HYDRAULIC
PUMP.
