32 GB mobial and plz give me ans
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
SOURCE: hai my nokia 3250 was not charging . the display
pls check the charger with the some other handset or change the charger and check it if still you facing the same problem you need to change the charger pin
SOURCE: charging problem
1st thing you should check is the charging port. It is not SOLDERED to the board and is only connected by 2 springed prongs. If you are hand, open the phone real carefully and gently bend the contacts forward. Also take a pencil eraser and wipe the contact connections on the phone. Then put your phone back together and see if it works. Good luck
SOURCE: lossing battry charging in 3second
the phone is not holding the charge you need to buy a new battery
