SOURCE: "Error! Reformat Internal Media as FAT16" what happened
I opened Windows Vista and used the Disk Management from Control Panel -> Administrative Tools -> Computer Management... If you notice, there's a drive on there with unallocated space (same drive letter as your MP3 player). Right-click that drive and select New Simple Volume. Make sure it's FAT and not FAT32 and begin the format. Mine works great now! Hope it works for you =)
SOURCE: reformat to fat16
1.Go to the faq by following this link http://mymusix.mmvoice.com/products/audio/PD-6070/faq.html
2. Scroll down until you see Q: How to recover
my player's firmware?
3. Follow those instructions.
Worked for me
SOURCE: Error! reformat internal media as FAT16
There are two ways to format an Mp3 player - one on the computer
itself, and one in Windows Media Player. Both methods will end up
erasing all the songs on the player, but the player will be "good as
new" after that. Sometimes reformatting in this manner will override
the player's native formatting and cause problems - this can be
reversed in most cases by updating the player's firmware. Firmware
upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or
FAT32. - Connect player to computer, double-click my computer, right
click on icon of mp3 player and select format. This only applies to
Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media
Player. Click on the Sync tab. Pull down the drop down menu underneath
the Sync tab by moving your cursor over the Sync tab and left clicking
on the little black arrow underneath the Sync tab. Highlight "name of
Mp3 player here 1GB" (wording may vary slightly), and then select
"Format." - this should erase everything.
-Tha Mp3 Doctor
SOURCE: Reformat Internal Media as FAT16
Depending on the requirements of the mp3 player, you may just have to right-click format in Explorer, or a computer guru friend to format it for you with a partitioning program if it needs a partition table.
every time i turn it on is says
and immediatly shuts down
and i just got this like 10 minuets ago
Every time I try this thing on get gives my a "Error! Reformat Internal Media as FAT16" and then shuts off.
