ITunes restore error 36
For Further Dial Apple Mac Repair Service 1800-582-2431 to get instant Support
SOURCE: Iphone "There is not enough memory available"
There needs to be sufficient disk memory on the PC to hold the contents of the iPhone (8GB or 4GB) plus some extra. This is because the iTunes backs-up the iPhone before the restore. Check and clear some space on your PC hard drive and try again.
SOURCE: iPhone 3G Error 0xE8000001
I just had this problem and it turned out to be... It didn't like my iPod cable. Switched to the iPhone cable and it worked.
Seems to be an iPhone 2.0 prob, or 3g prob, since I was using the iPod cable to sync my old iPhone just fine.
SOURCE: iphone restoration error (1601)
I found a solution!
It worked for me and many others (who posted their gratitude on the original post).
Below are the instructions you have to follow. If you have disconnected your phone or shut your iTunes, don't worry. I did it. I even reinstalled iTunes a few times and shut down the computer as well.
Here it goes:
"The way to get over the 16xx errors while restoring on any firmware is this:
Once you get the error DONT DISCONNECT IPHONE OR CLOSE ITUNES. Which leaves us with only one option, rESTART Iphone. STEP BY STEP GUIDE FOR VERSION 2.0.1:
1). You get the error. (Ofcourse)
2). DONT TURN OFF ITUNES. DONT DISCONNECT IPHONE CABLE.
3). If the phone is still on, reboot/restart the phone. If its off then kick it out of DFU mode which is explained in the NEXT step.
4). Press and hold the power and home button for some time to kick the phone out of DFU mode.
5). Itunes will detect it again.
6). Now try to simple-restore it, that is click on the restore button on itunes while pressing the shift button of your keyboard. YOU WILL GET THE 16XX ERROR AGAIN IN 5 MINS !!!! but dont worry, everything is under control.
7). now your iPhone will have the picture of the iPhone cable on its screen. good.
(DONT TURN OFF ITUNES. DONT DISCONNECT IPHONE CABLE.)
8). NOW put the iPhone it in DFU mode. How? Firstly turn the phone off (it might try to start up on its own again but turn it off again). Once its off, Press and hold the power and home button for 10 seconds, then release the power button but keep the home button pressed for another 10-20 seconds till itunes recognizes your phone.
9). NOW restore the phone by selecting the pawned custom firmware that you created and you will NOT get the 16xx error.
ENJOY."
I got this solution from here:
http://www.modmyifone.com/forums/pwnage/281841-error-1601-help-please.html
Hope it works for all of you.
Cheers!
Phil from Brazil
SOURCE: My 3gs iPhone is stuck in restore needed/emergency
Use the following steps to place your device into recovery mode. If the device is already in recovery mode, you can proceed immediately to step 6.
Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
While pressing and holding the Home button, reconnect the USB cable to iPhone. When you reconnect the USB cable to iPhone, the device should power on.
Note: If you see the screen pictured below, let the device charge for at least ten minutes to ensure the battery has some charge and then start with step 2 again.Continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button:Use iTunes to restore the device.
If you don't see the "Connect to iTunes" screen, try these steps again. If you see the "Connect to iTunes" screen but the device does not appear in iTunes, see this article and its related links.
When using recovery mode, you can only restore the device. All user content on the device will be erased, but if you had previously synced with iTunes on this computer, you can restore from a previous backup. See this article for more information.
