Please provide me the drivers for window 8
SOURCE: I haven´t audio in my P5KPL-AM (VIA VT 1708b) in Windows Seven
Hello Alejandro,
Asus do not offer Windows 7 drivers yet.
Sorry.
SOURCE: Mercury PI845Z drivers
check for the speed support of the board and graphic card there might be aclash of speed or try installing the hardware after os installation and then graphic afterwards motherboard utility
SOURCE: Drivers Pack For Windows Vista 7 is required
I will give you a
alternate and easy way for your problem.Just download this software
named driver magician and install it.It will search for the drivers for all your hardwares and components that doesnt have proper drivers and will download it.It will make your problem easy
http://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html
SOURCE: my motherboard is k8v-vm
Audio driver
You'll need to go to the Realtek website
Click The Downloads button at the top of the page.
Click the High Definition Audio Codecs (Software) link
Tick "I accept the above" then wait for the page to update then click Next.
You will now see a page of files available for download, at the top of this list is..
Vista, Windows7 Driver (32/64 bits) Driver only (ZIP file)R2.37 2009/11/20 38690k
Click on the first Go link for Site 1 and download the ZIP file.
Once complete, extract all the files from it and run the setup.exe file.
Run through the installation and it will ask you to reboot.
You now have sound !
Graphics drivers
As this motherboard was manufactured way before Windows 7 was released there may not be compatible Windows 7 VGA drivers for it.
If you go here there is a list of drivers or this board but none of them support Windows 7.
Try downloading the ASUS K8V VM Video driver for Windows XP, it may work.
SOURCE: drivers for ASUS K8V-MX Motherboard for windows 8
Hello here is the asus homepage:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=20&m=K8V-MX&os=&hashedid=dJ2XP7zr8tzeYbLp
Here is no drivers for windows 8.
Add a graphic card on the mainboard. This mainboard probably has the AGP slot, for adding a graphic card.
You just have to make sure, the driver is available for windows 8.
You can try the VIA drivers here:
http://www.viaarena.com/drivers.aspx
But i can`t give you a guaranty, the driver will work.
Good luck
