Question about Hitachi RAS-09UH Air Conditioner
Air conditioner stopped working
Recently moved into home - Hitachi RAS-72CHA3 model in lounge room - the remote turns unit on but only for a few seconds - then the timer lamp starts to flash and continues to flash and nothing happens. I have cancelled the timer settings from previous owners but to no use. The remote is working fine as I used it on the same unit in another room and it works fine.
I have the owner manual for this unit but it does not mention anything about a flashing time lamp. The unit outside is not turning on at all.
Can you help prior to me sending for an electrician.
Thanks Paul
    New Friend:
Brisbane Air Conditioning can help you resolve your problem related to air conditioning. Contact the nearest air conditioning installation & repair services now :
Address: 327 Bridgeman Rd Bridgeman Downs, QLD 4035 AU
Phone Number: 07 3269 8450
Email: info@brisbaneair.com.au
Website https://www.brisbaneair.com.au/
Air Conditioning Installation Experts Brisbane Air
Posted on Apr 28, 2017
My a/c 30000 BTu remote on time one minte good running than timer light flash any time wat happen plz wat solutions
Posted on Jun 05, 2010
  • 700 Answers
Check the breaker in the panel and the fuses in the disconnect at the outside unit. If that doesn't do it. call a heating and air technician instead of an electrician.
Posted on Mar 01, 2009
  • Fahr Quad Mar 06, 2009
    I take it that didn't help. I ran across a webpage that indicates the problem may be the fan. The site is at www.refrigeration-engineer.com/forums/showthread.php?t=16503. If that doesn't put you on the right path, let me know and I will see what else I can dredge up.
SOURCE:
I need a code for an unbranded remote that is a substitute for an Hitachi RAR-22Z remote (broken) The A/C model is RAS-5242
Turn the unit on. continue pressing the power button until it turns off. press set. (Each press of the power button sends a different signal)
Dec 13, 2014 | Hitachi Heating & Cooling
Hitachi RAS-09UH Air Conditioner won't turn on
If you can access the pcb inside, check the mini glass fuse
May 18, 2012 | Hitachi RAS-09UH Air Conditioner
I have a Hitachi ras-35ca1 unit and the remote control stopped working. I can manually turn the unit on but cannot change any settings. I brought a Digitech universal remote to control the unit but I...
Hello Rachael8104,
I unserstand that you are having a problem with you Hitachi air conditioner split nonduct unit. I have located a web page for you to contact the nearest local dealer to your area. Follow the follow url to the webpage and pick the closet dealer and see if they can not order you a replacement remote for your unit http://www.hitachiaircon.com.au/contact-us.aspx
Thank you for choosing FixYa.com
Justin
Apr 03, 2011 | Heating & Cooling
My hitachi ductless split room air conditioner with heat pump is not heating my room , i have cleaned out the filters and unplugged the unit for 10 min and plugged in back in and it only blows cool air , i...
dear sir
please reset you air conditioner by it,s remote to heat mode and check thermostat setting maybe it has been turn off after remove air conditioner,s electric supply plug from electric source . i hope after reset it will be able to work again.
hope answer the question
thank you
please vote!
Oct 03, 2010 | Hitachi RAS-09UH Air Conditioner
Instruction Manual need for a Hitachi DC Inverter room air conditioner model RAS-50YH4
http://www.hapm.hitachi-asia.com/index/techsupp/operationmanual/RAS_RAC-50YH4.pdf
Sep 08, 2010 | Heating & Cooling
Hitachi RAS-10C2M. What size of air conditioner
If the number you say is the model number, it appears to be a 10,000 BTU.Check on the sides of the unit, or inside where the air comes out, and it should give the numbers.It should say 5000 to1800 BTU, if it is a 110 volt unit. BTU is what you are looking for if you want the output, not HP.
Feb 23, 2010 | Hitachi Heating & Cooling
Hitachi RAS 5142CHA Won't operate
Check the fuse on the control board inside the head unit,if its ok you need to replace the contrl board
Apr 04, 2009 | Hitachi RAS-09UH Air Conditioner
Hitachi RAS-09UH Air Conditioner Logo
1,296 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
Marvin
Marvin
tony_tc1
Level 1 Expert
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
