Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Squeeling/hissing sound squeelin sound
  • Sony Master
  • 5,569 Answers
You are losing high voltage; if you sniff around the top or back of the set, you may smell ozone.
Pull the AC plug on the set overnight, remove the few screws holding the rear housing on, use a CLEAN (or new cheap) paint brush and if you have a vacuum with a hose, bring it along too. The CRT (picture tube) will be nasty, full of dust that is picking up moisture and creating a path for the high voltage to discharge and you need to clean it with the brush and it's better if you hold the vacuum hose close by so you can **** up the dust loosened by the brush.
If you clean it well (dry, not wet), the problem should be gone.
Posted on May 11, 2009
SOURCE:
"hitachi 42PD8700U FLAT TV HISSING SOUND THROUGH
Check and replace its audio output IC.
Aug 03, 2013 | Televison & Video
2001 Honda CRV makes a hissing sound (HISS HISS HISS HISS ) when makins a sharp left turn while going down a hill at about 30 MPH. The sound continues for about a mile after comming out of the turn a
sounds to me like something is rubbing on the tire. best bet would be to put the vehicle on stands and have a buddy turn the wheel back and forth while you watch from underneath. hope this helps
Mar 12, 2012 | Honda CRV Cars & Trucks
Hissing sound when stepping on brake
you may have worn brake pads sometimes they sound like there hissing just before they hit the warning track which will begin to squeel
Mar 29, 2010 | 1996 Dodge Ram
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Loud hissing through rear (souround sound) speakers
I have the Sony Bravia KDL-46S4100. The high-picthed hiss drives me insane. I have a work around but not a fix. Go into your TV's menu and find BACKLIGHT. Adjust it from 1-9 with the house quiet and find what frequency of the hiss is the least annoying.
Sony Bravia high pitch hiss hissing sound high frequency
Nov 22, 2008 | Audio Players & Recorders
Hissing sound inside my sansui tv
You have a short on the secondary side of the transformer that is hissing. You are going to need someone knowledgeable in electronics, to help you find the short. Most likely it is your Horizontal output transistor.
Sep 08, 2008 | Sansui Televison & Video
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
119 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
