Washing Machines Logo
Anonymous Posted on Mar 23, 2013
Tub seal for simpson ezi sensor 8kg. not avail from manfacture, must buy complete expensive gearbox, bearings are easy where can I get a suitable seal from ?
Ub seal for simpson ezi sensor 8kg. not avail from manfacture, must buy a complete & expensive gearbox, bearings are easy to replace ,allready have them. where can I get a suitable seal from ?
Anonymous
Level 3:
  • Washing Mach... Master 1,010 Answers
  • Posted on Mar 23, 2013
Anonymous
Level 3:
Answers
1010
Questions
Helped
246833
Points
3078
In Canada you can buy it the Canadian Bearings, in the USA, sorry I could not help
  • Anonymous Mar 23, 2013
    Fantastic. have got a part#, I looked at the website and came away totally confused
5 Related Answers
Anonymous
  • Posted on Mar 11, 2010
SOURCE: We are using our Electrolux/Simpson Ezi Sensor washing
also have the same machine - if you wash with the eco rinse the clothes will ALWAYS have the soap residue on them and if you use the deep rinse then this machine will just sit there doing the very occasional agitate for up to 6 hours - can't win - have only just hung out a load and as usual there are many many dry spots on the sheets which is a daily occurence - really hate this machine and it's so called u-beaut functions -
Anonymous
  • Posted on Aug 04, 2009
SOURCE: Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
luisa_sgro
  • 713 Answers
  • Posted on May 17, 2011
SOURCE: simpson washing machine 8kg ezi
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Jun 02, 2011
SOURCE: Kenmore Oasis washer--model#11027082604 is leaking
As far as I can remember there is supposed to be a lip seal for this motor. I must apologize because I am not sure this is 100 % correct... but this number 425009P is on one of my old invoices. I am NOT sure that seal is for an Oasis. I am sure it is for a smart drive machine.
I did a net search for that number and it only shows up on the Fisher and Paykel machines that are similar to the Oasis. See for your self and feel free ask / seek another expert.
Kelly
Kolbrun Gunnarsdottir
  • 1228 Answers
  • Posted on Feb 26, 2012
SOURCE: Hi I have a Simpson 8kg washing machine ezi sensor
Those machines with a will of their own can be difficult to handle.
Ask the electician if there could be something wrong while spinning.
kolbrun
Hi my Simpson eziset 9.5kg model 22s950 has oil splatter underneath the machine and making noise could this need bearings replaced and if so is it difficult to do myself. Thank you
Oil will be coming from the gearbox. Oil seals can be replaced if you can source the seals where you live. If gearbox shafts or bushes are worn then a new gearbox would be needed, Machine has to be completely stripped down & both bowls removed from the cabinet to do the work. Tub seal & bearings will need to be replaced as well. Lot of work & lots of tools needed.
Simpson 8kg Ezi won’t remove all water after spin cycle complete.
check for something in the pump impeller stopping it from spinning properly
1helpful
Simpson ezi set 605. has what sounds like a bad bearing noise during spin cycle only.
Drum bearing failure - easy fix if you are good at repairs part cost £15.
Email : [email protected]
2helpful
Oil on cloths after wash
Simpson washing machines are known for this, The seal in to top of the gearbox fails which allows water to enter the gearbox, this forces the grease out of the gearbox into the machine, The fix is an expensive gearbox swap.
1helpful
Hi I have a Simpson 8kg washing machine ezi sensor and it won't spin the red lid light beeps continually and flashes it's only 2 yrs old and never had any other trouble with it??
kolbrun
1helpful
2answers
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi, i have an Simpson Ezi Set 950 - Top Loader that im looking at bying online that needs a part 4 runing order, just wondering if u knw if and were i can get the part witch is (main Bearing) for it and if...
Hi just read your posting.Now how old is this Simpson.When I have replaced bearings in the EZI SET range of washing machines I always have to change both bearings and the main seal as well.Can you tell me why you need to change this bearing,Is the machine noisy on spin?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
3helpful
Top Washing Machines Experts
john h
