Nikon Coolpix S3100 14.0 Megapixel, 5x Optical Zoom, 2.7 In LCD, HD Video Digital Camera - Black Logo
Deon Saayman Posted on Mar 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nikon coolpix s3100 soom lens sticky dont want to push out
Optical zoom is sticky and can not come out mooving out aboute 5 mm max then start shatering. And also dont want to move back got to remove battery and replace before moving back
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on Mar 22, 2013
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10441227
Points
622693
Nikon COOLPIX camera lens error
Clean the sides of the lens with a piece of paper, air blower,other vedios are available in YouTube. It's better take professional help
Nikon s2700 opens up but will not zoom and comes up with lens error
try to reset cam to factory default - try again if not helping looks like your lens broken (if you didnt let it drop) warranty ?
NIKON D3100 zoom problem
The D3100 doesn't have digital zoom capabilities. The zoom range depends on the lens you have fitted on. The 5.6 sounds like the aperture. The maximum aperture also depends on the lens.
The S3100 does have digital zoom capabilities. Is this the camera you're referring to? Or are you confusing the specs of the two cameras?
1helpful
If you had a compact camera it would say 10x zoom what is the equivilent in a 70mm -300mm tamron
A 35-80 mm lens is 2.3X zoom. Divide 80 by 35 and you'll get the result.
It is usually better to know what the focal length of a lens in "35 mm equivalent" is and judge by that, rather than relying on the "X" power of the lens. For instance, most point and shoot cameras start at about 35 mm and have either a 3X or 4X zoom. This would make it a 35-105 or a 35-140. I've seen some that start at 28 mm, though. A 3X starting at 28 mm is 28-84 and a 4X is 28-112. Neither one is a particularly strong telephoto lens and the 4X is just about the same as the 3X that starts out at 35 mm.
It's also important to realize that tradition dictates that lens focal lengths are usually expressed in terms of "35 mm equivalent," where "35 mm" refers to a 35 mm film camera. This is because of the relation between the sensor size and the actual focal length of the lens and the resultant angle of view of the lens.
I have one point & shoot that is actually a 5.8-24 mm zoom. This is a 4X zoom. The 35 mm equivalent is 28-116 mm. The sensor is 7.2x5.3 mm. (1/1.8") (And I wish I knew someone who could explain how the heck they came up with sensor size terminology!)
I have another point & shoot that is actually a 5.7-17.1 mm zoom. This is a 3X zoom. The 35 mm equivalent is 34-102 mm. "How could a shorter focal length give a longer 35 mm equivalent?" you might ask. It's because the sensor is only about 5x4 mm. (1/2.5")
I have a few Nikon DSLR's and - thankfully - they all have the same size sensor. They all have a "lens factor" of 1.5. This means that you just multiply the actual focal length of the lens to get the 35 mm equivalent and then you can make comparisons accurately from camera-to-camera. Most Canon's, for instance, have a lens factor of 1.6. On a Nikon DSLR, a 28 mm lens is the "35 mm equivalent" of a 42 mm lens. On most Canon DSLR's, the same 28 mm lens is the equivalent of a 45 mm lens.
These example are just to show you how freaking confusing it can all become if you try to make sense of the "X" power of a zoom lens.
Bottom line...
Check the 35 mm equivalent specifications for the lens. This way, you will be leveling the field and comparing apples to apples. More or less.
I have a nikon coolpix s3000 purple.it is 12 megapixels 4x wide zoom and 2.7 inch lcd-zoom was out-not kept in case-dropped on carpet on cruise ship maybe about 3 feet-get lens error-screen comes on but...
Your photos will not be affected by this fault. Just take the memory card out of the camera and read it with a card reader attached to the computer.
Unfortunately the camera will probably need an expensive repair, or if that isn't economic, replacement.
It does'nt push the lens it says lens error. what will i do? my camera is nikon coolpix s500
The sled motor start malfunctioning it needs repair by an expert to open the lens section and fix the problem. Please contact any expert nearby, otherwise you must replace the complete optical zoom section.
Thanks
Nov 09, 2010 • Cameras
Top Nikon Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Nikon Video Camera Expert? Answer questions, earn points and help others
