Nordic Track X11i Commercial Incline Trainer Treadmill Logo
Angel Reed Posted on Mar 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Manual for the X11I INCLINE TRAINER
ernesto cuadra
Level 3:
Top Expert:
  • Nordic Track Master 12,223 Answers
  • Posted on Mar 22, 2013
ernesto cuadra
Nordic Track Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080064
Points
34431
Please go www.fitnessmanualsonline.com
and download for free. God bless you
My freemotion i5.3 incline trainer shut off while I was walking on it and now it will not turn back on.
I have a Freemotion i5.3 Incline Trainer. When I run on it at 4+ MPH it makes loud bangs when my foot land on the platform. I usually walk on it at higher incline and just recently started running on it. The bangs are much louder at 0% incline than at higher inclines for the same speed. What might be the problem?
Incline not moving
Try to do the following hope it will solve the problem.
if its doesn't solve the problem then the the incline motor or the control panel is faulty.
HOW TO USE THE SETTINGS MODE T
he console features a settings mode that allows you to connect your incline trainer to your own wireless network and to log in to your iFit Live account. The settings mode also allows you to turn on and turn off the display demo mode. You may also be able to select the unit of measurement.
Select the settings mode.
Insert the key into the console . Next, select the start menu. Then, press the i button in the lower right corner of the screen to select the settings mode.
Select the maintenance mode.
Press the Maintenance button in the lower right corner of the screen to enter the maintenance mode.
Calibrate the incline system of the incline trainer.
Press the Calibrate Incline button. The incline trainer will automatically rise to the maximum incline level, lower to the minimum incline level and then return to the starting position. This will recalibrate the incline system. Press the Begin button to calibrate the incline system or the Cancel button to return to the maintenance mode. When the incline system is calibrated, press the Back button. IMPORTANT: Keep pets, feet, and other objects away from the incline trainer while the incline is calibrating. In an emergency, pull the key from the console to stop the incline calibration.
Restore factory defaults.
If necessary, press the Restore Defaults button to reset the firmware to the original factory firmware. This will erase all firmware updates that you have downloaded. Press the Begin button to restore the default firmware or the Cancel button to return to the maintenance mode. When the restoration is complete, the words PLEASE CYCLE POWER will appear in the grey box. Press the power switch into the off position. Wait for several seconds, and then press the power switch into the reset position. It may take a minute for the console to be ready for use.
Exit the maintenance mode.
To exit the maintenance mode, press the Back button repeatedly.
www.electro-medical.blogspot.com
How to recalibrate 8600 incline trainer
To initiate the calibration routine, hold down the SPEED +
button and the SPEED - button simultaneously for three seconds. During the calibration routine, the INCLINE
TRAINER will automatically rise to the highest incline level and then return to the lowest incline level.
P.S. This is listed in your user manual in the "Troubleshooting" section if you don't have a user manual then you can get a pdf copy of it here
http://www.ereplacementparts.com/images/nordictrack/CTK59020.pdf
How should I lube my NORDICTRACK X11I
Check the video all the treadmill follows the same procedure of lubricating it.
Incline not working
The Trainer is reading; Serching for motor controler
Will my ifit treadmill card work in an incline
Technically, the Incline Trainer and the treadmill are two different type of machines. The incline trainer raises much higher so the card that is designed for the treadmill will not work on the incline trainer unfortunately.
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
