A yellow question mark in device manager in cd drive.
Check the connections and then check the drive manufacturers website for the latest drivers. It is unusual for a CD to lose drivers so you may have a Virus problem or a failing CD drive.One thing that may be causing the problem is if you have just fitted the drive and didn't set the Slave or Master jumper correctly. This will only apply if you have IDE drives of course.
SOURCE: Unable to boot from USB fey on D850MV Motherboard
Download updated bios here
follow instructions carefully to update bios
use the F8 key right after power up to select boot device.
SOURCE: BIOS settings to boot from bootable USB Key
Hello
Here is a link for your motharboard manual
ftp://download.intel.com/design/motherbd/mv/A6514501.pdf
Your needs are in page 113
AYADI
SOURCE: sound problem
1. Re-Install the Drivers of the sound card with carefull attention.
2. Restart the system.
Let me know if your problem is solved and rate me as FIXYA!
SOURCE: gbt on board sound drivers
driver are not installed.... t get them you have to type your motherboard name in any search engine and type sound driver download free.
Eg-"Intel D915GAG sound drivers+free download"
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug
them back this should activate the found new hardware wizard or
you might have to uninstall
then restart your computer then reinstall your DVD/CD then reinstall the driver
for this device
if your computer came with
a motherboard disk the drivers could be on it
click start control panel
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x right
click you will need to update the driver
or
select properties general troubleshoot, select driver
click to reinstall drivers click update driver
hope this helps
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then go click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
http://majorgeeks.com/downloadget.php?id=5240&file=15&evp=5fbb1c6e47482358c61a5236fb38a112
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
