It runs good but sounds rough. i cleaned the brush and checked the belt. that all good.
It could be the bearings at end of brushbar,take belt and brushbar off and see if it's ok, if ok would sudjest replaceing bearings
http://www.riccar.com/ftp/whitepapers/RSL_SupraLite_OwnersManual_8-08.pdf
SOURCE: brushes stopped working and started making real sound sound
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40488&thid=754331
Brushes stopped working and started making real...
Posted by charlenemo on Jul 07, 2008
I was on my 2nd room and the brushes stopped working and it spells like a belt broke but there are no belts on the machine. Also making a louder sound.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac F5914-900 Spin Scrub Upright --- If the vacuum does not have a belt there has to be something driving the brushes of which a part is broken and is in need of replacement. Please check your owner’s manual under the trouble shooting guide to see what is wrong, or feel free to call the Hoover factory website or phone 3 to cust serv @ Hoover to see what is wrong or to have them send out an owner’s manual to you for future use. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: Dyson Animal 17 - brush stopped turning
The belt will stop itself from spinning if you accidentally picked up a shoestring or vacuumed the edged of a carpet and the carpet got caught. To have the brush spinning again, simply step on the front of the machine, pull back the handle, turn the machine on with the red power button and press the gray button next to the red button - that's the ON/OFF button for the brushbar. If it doesn't spin, press and hold the button down for 10 seconds. If it still doesn't work, call the Dyson helpline, they'll have you open up the cleaner and inspect the belt and brushbar motor and if all else fails, they'll refer you to a local repair dealer in your area to fix it.
SOURCE: Riccar 8800 belt replaced but now floor brush won't spin
Are you sure that you get the right sized belt? This is the correct one you need:
Riccar 8800 Belt
SOURCE: My Dyson CDC14 Animal just started making a wierd
Something could be jammed, or not rotating freely, maybe an improper alignment with the brushes, or a blocakage within them. Try to re adjust the brushes :)
SOURCE: riccar model rad.7 upright (radiance). roller
As you already know, the red brush indicator light indicates that the brush roll has stopped turning, usually because an object has become stuck in the brush roll. When that happens you should turn the machine off (unplug it also for safety), remove the obstruction and turn the vac back on. That should have cleared the light and allowed your brush to turn again.
Occasionally, you will get debris in the brush roll end caps and the brush roll will spin slower making the sensor think there is an obstruction. You can remove the brush roll, pop the end caps off and clean out any debris to see if that helps.
If none of the above worked it is possible that the brush roll sensor is bad or the circuit board in the machine is bad. You'll need a Riccar service center for that. The good news is your Radiance has a 6 year warranty.
