Electrical Supplies Logo
A
Anonymous Posted on Mar 22, 2013
Leviton remote control model no. 06696XMT not working
My remote control switch doesn't turn on or turn off the light....it's not connecting to the hard wired switch.
5 Related Answers
Anonymous
  • 19 Answers
  • Posted on Jan 04, 2009
SOURCE: Connecting Leviton Decora light switch.
At the switch you have a feed wire coming in this brings in power which originates in the electric panel. You also have a feed or feeds goings out to other lts or switches, this you seem to have on the switch. instead of the closet switch loop.undo all the wires. find the only hot this is the one wire you can touch to the others and make different lts come on i reccomend getting a electric tester to do this. FInd the wire that goes to the closet lt. Once your sure put it to the side. wirenut all other wires together with the hot wire. this makes all other switches independantly hot. connect the hot to the switch and the closet lt to switch. I HOPE THIS MAKES SOME SENSE TO YOU . let me know if i can help
Anonymous
  • Posted on May 05, 2009
SOURCE: Leviton Single Pole Switch with Pilot Light Model 277W Box
Depends on whether you want the pilot to glow when the circuit is live (the main light is on) or to glow when the circuit is off. (The switch can be used either way, and I have used this switch in both configurations at different places.)
The wiring diagram is on the inside of the box.
In indicates that if you want the pilot light to glow when the circuit is off, then you only need two wires (the live and the return, usually colored black and white, respectively). However, you also need a ground. The instructions say that you need the ground for safety (and probably legal code) reasons, but I suspect that, without the ground, the pilot light won't work in this configuration.
However, if you want the pilot light to glow when the circuit is on, you probably need a three wire configuration (plus the ground).
Hope this helps.
Anonymous
  • 10865 Answers
  • Posted on Jun 02, 2009
SOURCE: Installing a Leviton 5225 switch with outlet.
A switch is wired using the hot wires only, the black wire. It is simply a break in the line so that when the switch is off no power flows and when the switch is on the power does flow.
You are correct that the middle outlet would have two black wires and two white wires.
If you want to tap into that middle outlet and run power up the wall I suggest you look into some wiremold products. Go to their website, or any home depot and check it out. Get back if you think I can help you further. I am an electrician.
Here is a link that may help you.
http://www.make-my-own-house.com/electrical-wiring-diagrams.html
Anonymous
  • 45 Answers
  • Posted on Aug 25, 2009
SOURCE: How does the illuminated light work inside a
The neon lamp inside of the switch draws very little current (milli, or mico amps) so there is no significant current flowing to ground.
As for your real question, there are several various types of 3-way pilot switches:
Load on: Pilot on
Load off: Pilot on
Some 3-way pilot switches have an external lead which allows them to be configured either way.
If both of your switches are the same type and are wired correctly, they should work the same.
If you suspect that one is defective, try swapping them.
Testimonial: "Thank you very much. It turns out one of the two was simply dective. Thanks!"
john h
  • 29494 Answers
  • Posted on Feb 22, 2010
SOURCE: I'm using a Leviton 1755 combo 3 switch for a bath
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Remote control model 06696xmt will no turn off a lighting circuit. if I turn on the smitch manually it the remote will turn it off but it will not turn it on. have replaced batteries.
Check to see if the "off" button on remote is working. You may have to disassemble the remote and clean out the contacts involved to restore operation.
I remodeled my kitchen and replaced my leviton dimmer switch with another brand. After installation I turned the light fixture on. Only one of the three lights of the single fixture turned on for...
Hi Leonard,
I'm a licensed electrician and will be happy to help you get this working again. I suspect an incorrectly wired or incompatible switch or a load that is not designed for dimming. To know which one(s) is the problem and to be able to provide a solution, I need a little more information.
1) What was the old switch brand and model number?
2) What is the new Leviton switch's model number?
3) What type of light bulbs are you trying to operate in the 3 fixtures?
4) What is the number of and wattage of each lamp in the fixtures?
5) How many switches operate the lights?
5a) If more than one switch is used, what is the brand and model number of the other switch(es)?
Thanks
Locator Light not working on leviton 6633-pl
6633-pl is single-pole and 3-way dimmer made for max 600 watt incandescent or halogen load. This dimmer does not work for CFL or inductive loads such as motor.
I have no idea what a 'locator light' is?? Do you mean the LED indicator that shows when power is connected?
Troubleshoot section of manual does not show any solution for LED malfunction.
Contact Leviton for email tech support:
http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=37619&minisite=10251
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I am replacing a Lightolier 3-way Dimmer switch with a Leviton IPI06-1LX Dimmer switch. When I install the dimmer switch it works fine. But the on/off regular wall switch won't turn the light on or...
It depends. Some dimmers are considered "smart dimmers," where the control on the other end of the 3-way has to be intelligent enough to send a signal back to the dimmer. If the Lightolier dimmer was a smart dimmer, then chances are that the 3-way control was designed to talk only to that specific dimmer. The Leviton product you replaced it with is a simple, basic dimmer - it should work in conjunction with a simple, basic 3-way switch.
If the 3-way control already IS a simple, basic 3-way switch - then I would simply re-check the wiring of the dimmer you replaced.
2answers
We have a ceiling fan Apollo 52' Model 355-6788 but we don't have any instructions on how to put it up. Please send us instructions on how to do this.
On the remote part that goes inside the fan, it has five wire on it. One Red wire marked L goes to black switch wire from switch or Hot wire. Other Red wire goes to Net. wire from switch.or feed.Then you have A black, a blue & a white. They connect to wires from the fan. When finished connect turn light switch on, leave on & used remote control. Top left button controls the fan on/off. bottom left button controls light on/off.dimmer. There you go, all the know how to connect remote & fan/light up. Good Lucky.
P.S. You will need to buy a 9v battery for the remote, it doesn't come with it
We have Leviton push button slide dimmers w/the locate lights for power outlets and lights throughout our house. A couple of months ago one stopped working...you push the button to turn it on and it...
Wiring is not best suspect.
If all the Leviton devices were installed same time, they may be failing at same time due to lifespan.
For example, ordinary on-off switch is a mechanical device with mechanical parts, and mechanical switches last many years longer than wiring devices that have electronic parts.
Electronic devices usually have standard 1 year limited warranty.
http://www.leviton.com/OA_HTML/ibeCZzpHome.jsp?minisite=10025&respid=22372
I'm trying to replace Lviton OH3504 Photelectric switch with wires coming out of device for connection. I'm replacing with a Leviton 4 way swith 5604 with no wiring just screws. I'm using...
Need more information.
Project is not clearly defined.
Add a comment with clear description of each wire and what Load is being controlled.
Why are you using a 4-way switch? Are you controlling 240Volt circuit?
Photoelectric switch usually has red, black, white wires, and usually replaces a single pole switch but can also be used to control 240Volt circuit in some wiring diagrams.
http://waterheatertimer.org/images/Wire-photo-eye-125.jpg
4-way switch has 4 screw terminals and is generally not used to replace a single-pole photoelectric eye, but can be used to control 240Volt circuit in some wiring diagrams, so I'm not sure what you are doing.
http://waterheatertimer.org/images/Typical-3-Way-switches-450.jpg
Upvote the help, and add a comment
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
1helpful
2answers
I am trying to replace a two wire light switch(both white) with a leviton photoelectric 3 wire motion activated light control(red, black and green). I am trying to determine which wire goes to which?
one of the white wires has power on it constantly....that wire connects to the black wire of the leviton.......the other white wire which has no power to it is going to whatever needs power so that wire connects to the red wire of the leviton....the green wire connects to the metal box where your mounting the leviton.
1helpful
Leviton Programmable Timer 6124H-W installation problem
I Have a decora 24 hour lcd programmable timer switch 6124, when i set the timer it doesn't go on, but it goes one a 5:00 am. when there is nothing programed?
Apparently i need to set the time first and then program timer?
Can you please help. Thanks so much.
I need to program a VRi06-1LX rf switch with a harmony remote
The VRi06-LX switch is in the Harmony database.  Log on to your account, select the Device tab and click on the Add Device button.  Select Home Automation/Light Controller from the drop down menu.  Then select Leviton and type in VRi06-LX for the model.  The next screen will show two models, select the VRi06-LX.  Go through the rest of the process to save the data and revise your programs if necessary.  The changes will not take effect until you update your remote.
Top Leviton Electrical Supplies Experts
john h
Sean Wright
Sean Wright
CJ Rock
CJ Rock
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
