Question about Dell OptiPlex GX260 PC Desktop
Input signal out of range
When i try to boot up my computer all goes well until the first loading screen. after that any color on the screen has green bars branching from it that cover the screen. when i get to windows i usually only have about 30 seconds before the screen goes black and says "input signal out of range"
  • 3 more comments
  • wavid_rzm Feb 28, 2009
    i am using windows vista, and i have a GeForce 8600 GT video card
    sorry XFX GeForce 8600 GT video card.
    yes it did thanks
  • Anonymous May 11, 2010
    Also what operating system?
    What type of video card are you using?
  • 59 Answers
You could try going into safe mode and make sure the correct drivers are installed and if they are then you can then set the correct resolution.
Posted on Feb 28, 2009
  • Anonymous Feb 28, 2009
    Did this help?
SOURCE:
Green tint on tv
Is entire screen green or just tint range will not move?
Look at set with color off to zero and also try different inputs.
Advise me source of signal and how or where you are connected.
Jun 13, 2012 | Seiki SC221FS 22 Class LCD HDTV
I TRIED TO RESET THE RESOLUTION. THE SCREEN WENT BLANK AND THE MESSAGE ON THE SCREEN SAYS IMPUT SIGNAL OUT OF RANGE
I believe the max resolution this LCD can support is 1440 x 900 / 75 Hz. If you set your display resolution higher then that, you will receive the input signal out of range error. Your LDC turns off to protect it self from the invalid settings. If you can not change it back once your PC boots to windows, you may have to do it in save mode by pressing F8 once you power on your PC and before the windows loading screen starts.
Regards, Chris
Jun 29, 2011 | Hannspree 19" Widescreen LCD Flat Panel...
I changed some setting for the computer resolution and now my monitor just says no input signal..the hard drive turns on and then goes into sleep mode and says no input signal. How can i fix this problem?
Possible reason is that input signal goes out of range that probably a Screen refresh rate that the monitor cannot handle. Instead of bursting into flames, the monitor shuts itself
down as a protection feature. Look at the monitor manual if you got one.
Safe Mode should allow the monitor to work in the problem account.
Try this.
Boot in Safe Mode (see below)
Switch users to the problem account
Right click the desktop
Select Properties
Click the Settings tab
Click the Advanced button
Click the Monitor tab
Select: Hide modes that this monitor cannot display
Select a different Screen refresh rate
Click Apply twice and then Click OK
Or try this:-
power on the system and press and hold F5.
When a screen appers with some option, try to find a option something realted with VGA setting.
Click that option and let pc start normally.
It will surely work
Dec 10, 2010 | Hannspree HW191D LCD Monitor
Boot up computer. Nothing comes up on screen. Get a message:"information. No input signal." Everything is plugged in correctly.
  • check the cable on the monitor screen
  • if after removing the data cable from the computer and it has no vertical color screen then
  • try other data cable
  • try other monitor screen
May 02, 2009 | Computers & Internet
My screen turns green and then turns off
you need to adjust the screen voltage. behind the front grille and inside cover. a small black box 6 adjusters protruding from it. only adjust the the color counterclockwise that matches the problem in this case it's the green so look for the knob with "G" marked by it. there are 2 with "g" marked by them the row across the top of the box are for focus don't adjust. back the knob off untill the raster is blank with your input set to an inactive input, the picture should be blank and black.
when it is you have the adjuster close to where it should be, now change the input to an active signal and turn the color off so that you wil have black and white picture. adjust that knob untill you do have a truely black and white picture not too green or red or blue. go back to inactive video input and check that there are no lines of any color on the screen. repeat if needed. always adjust these knobs slowly the set will be watching you ! if your autofocus won't work now you have the adjustment set too low. check this function before putting back together again. these adjustments can be real touchy so be patient
Feb 20, 2009 | Sony KP-57HW40 57" Rear Projection...
Westinghouse LCM22W2 shows a display then turns off after half a second
I have the same problem and have traced it down to a potential power supply issue.  I bought mine at Best Buy in '06 and was told today that they will test the power supply for free.  It may range from $50.00 to $100.00 depending on where you can get it.  This does not include labor for those not qualified to work with electronics.  Hope this helps you.
Aug 13, 2008 | Westinghouse LCM-22w2 Television
Input Signal Out Of Range
press F8 upon booting up instead of choosing safe mode click ENABLE VGA right click desktop, click properties, click settings, set resolution to 1024 x 768 from there you will not see anymore the Input Signal Out Of Range
Apr 11, 2008 | Akai LCT2060 Television
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
On Pwr up logo appears then LCD returns to stanby Black screen
I will assume the monitor is staying on during the boot process all the way until Windows loads.
If that is the case, then...
  • Start the computer
  • wait until the initial bios/logo screens for your motherboard go away.
  • Press F8 to get the Windows recovery boot menu
  • If you see the Windows Logo you would normally see then press rest and try again.
  • In the recovery screen, select SAFE MODE
  • Boot into Windows and uninstall your video card.
  • Reboot the computer the normal way through the start menu.
  • When your PC starts back up it should then reinstall the video card, and set itself automatically back to 60khz as default.
Let me know how you go =)
Jan 20, 2008 | BenQ FP71E 17" LCD Monitor
Some monitors have low resolution, that if it doesn't support that resolution then you'll expect an "input signal out of range" message on screen. try to boot on "safe mode" if it works then you have to lower your screen resolution at "display properties" if not then the monitor has a defective data cable. ;)
Oct 30, 2007 | HP Pavilion F1523 15" LCD Monitor
Dell OptiPlex GX260 PC Desktop Logo
278 people viewed this question
Ekse
Clive
Clive
