Its simple, you have reboot with console connect, get into to ROM mode and change configuration registry so it will not load the saved configuration. Please refer Resetting the passwords on Cisco ASA 5510 Binary Royale Ltd for the step by step process
SOURCE: ASA 5510 sec - bun k9
Basic Commands
pixfirewall(config)#hostname PIX
!--- Naming the PIX is optional.
PIX(config)#nameif ethernet2 fo security20
!--- Naming the interface is optional. It is recommended that you
!--- hardcode the speed/duplex.
PIX(config)#interface ethernet2 100full
!--- Bring up the interface.
PIX(config)#ip address fo 192.168.1.1 255.255.255.0
!--- Assign an IP address.
Failover Commands
PIX(config)#failover ip address fo 192.168.1.2
!--- IP address for the failover link.
PIX(config)#failover lan unit primary
!--- This unit is primary
PIX(config)#failover lan interface fo
!--- The 'fo' interface is used for LAN failover.
PIX(config)#failover lan key cisco
!--- The Pre-shared key.
PIX(config)#failover lan enable
!--- Enables failover.
!--- Start the failover process.
This message appears on the console:
LAN-based Failover: trying to contact peer
LAN-based Failover: Send hello msg and start failover monitoring
SOURCE: Activation key
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Step 1
Obtain the serial number for your security appliance by
entering the following command:
hostname# show activation-key
Step 2
Access one of the following URLs.
Use the following website if you are a registered user of
Cisco.com:
http://www.cisco.com/go/license
Use the following website if you are not a registered user
of Cisco.com:
http://www.cisco.com/go/license/public
Step 3
Enter the following information, when prompted:
Product Authorization Key (if you have multiple keys, enter
one of the keys first. You have to enter
each key as a separate process.)
The serial number of your security appliance
Your email address
An activation key is automatically generated and sent to the
email address that you provide. This key
includes all features you have registered so far for
permanent licenses. For VPN Flex licenses, each
license has a separate activation key.
Step 4
If you have additional Product Authorization Keys, repeat
Step 3 for each Product Authorization Key.
After you enter all of the Product Authorization Keys, the
final activation key provided includes all of
the permanent features you registered
SOURCE: installation of cisco asa 5510 firewall
The problem is your version of java, you need to uninstall java 6 update 11 or 12 and install java 6 update 6. you can download this from the archive section at the java web site. I had the same problem but this solved it.
Good luck
pls send me a line if your problem is solve
[email protected]
SOURCE: Restart Cisco Asa 5510
Yes. The firewall will restart. Just be sure to save your running config to memory before turning off. For that you must issue the command: write memory.
Best Regards,
T
